Subie conversion questions |
Jul 6 2013, 12:22 PM
I'm interested in doing a conversion with both a subie engine and trans. What are the best donor cars to look at if I wanted a 6 cylinder engine and trans from the same car. Cable shifter if possible. Thanks, Mark
76-914 |
Jul 6 2013, 05:00 PM
You want to go out of the USA then.AFAIK, all of the six's were automatics here.
BIGKAT_83 |
Jul 6 2013, 05:36 PM
Senior Member Group: Members Posts: 1,798 Joined: 25-January 03 From: Way down south Bogart,GA Member No.: 194 Region Association: South East States |
No subaru manual transaxle comes with a cable shifter.
The only six with a manual transaxle imported to the USA was the 2.7L 1988-1991 XT. I don't think you would want that one! |
Chris H. |
Jul 6 2013, 05:56 PM
Senior Member Group: Members Posts: 4,030 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Yeah you need a 3.3 six engine out of an SVX (all were automatic) or the newer 3.0 or 3.6 that come in Outbacks and other cars. Then find a WRX trans, ideally from a turbo year (5 speed, not 6). It will bolt right up, but you have to convert it from AWD to 2WD by removing the center diff and blocking the end off with a plate. Then as Bob is hinting at you have to make your own cable shifter linkage and use an Mr2 or 1990-1992 Honda Accord shifter. Do some searches and you'll narrow down what looks best for you.
Dr Evil |
Jul 6 2013, 08:19 PM
Screw that, go 3.6 EZ36. That is where we need to be going.
Lo-Fi Version | Time is now: 15th May 2024 - 08:48 PM |
