Sorta on-topic: Henrob welding/cutting torch??, decent alternative to TIG??? |
Mueller |
Dec 2 2004, 11:01 PM
I've been wanting to do some aluminum welding and I don't want to deal with trying to do with the MIG welder I have since I've read that the results are less than satisfactory.....I'd love to have a TIG welder, but the cost is too much to justify....
so, has anyone used one of the Henrob torches?? Henrob 2000 Is it just marketing hype compared to a regular Oxyacetelyne setup?? In the latest Eastwood catalog, they have a picture of them welding up a type I head....all show or a viable method?? |
ChrisFoley |
Dec 3 2004, 06:49 AM
I am Tangerine Racing Group: Members Posts: 7,925 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I saw a demo. Its a lot better than the old style oxy-actylene torches, and has some benefits over TIG like built in preheat, but Tig is still tops IMO.
(IMG:style_emoticons/default/welder.gif) |
scotty914 |
Dec 3 2004, 07:35 AM
suby torque rules Group: Members Posts: 1,525 Joined: 20-July 03 From: maryland, the land of 25 year Member No.: 924 |
i just spent 30 mins watching their videos on line, i like the way it seems to work, i dont have any type of welder, cutter just a good old fashoned propane torch. if i only had 500 buck for it and tanks, i would get it
John Kelly |
Dec 3 2004, 07:59 AM
Senior Member Group: Members Posts: 692 Joined: 1-May 03 From: Moclips WA. Member No.: 640 |
I've had a dillon/henrob for years...to be honest it is a little more fancy than what I need for gas welding steel. You might see a difference when welding aluminum sheet metal. The demos are amazing, but if you are just welding sheet metal, any good torch will do the job. The dillon is a little heavy for long use. Gas welding is the preferred method for aluminum car builders because the metal stays a little more soft and workable than with a tig. Welding heads...I don't know about that.....
John www.ghiaspecialties.com |
Lo-Fi Version | Time is now: 16th May 2024 - 05:16 PM |
