Transmission blast, any reason NOT to do it? |
shawn914 |
Jul 8 2013, 01:21 PM
Member Group: Members Posts: 185 Joined: 13-February 12 Member No.: 14,126 Region Association: MidAtlantic Region |
Cleaned the "easy" stuff off the transmission. I am considering taking it to a blaster for a CLEAN sweep (the shop uses glass or walnut). Could then be painted too, after a rebuild. Is there a reason(s) to not media blast the transmission (EXTERNAL surfaces only)?
Shawn |
Mark Henry |
Jul 8 2013, 01:53 PM
Cleaned the "easy" stuff off the transmission. I am considering taking it to a blaster for a CLEAN sweep (the shop uses glass or walnut). Could then be painted too, after a rebuild. Is there a reason(s) to not media blast the transmission (EXTERNAL surfaces only)? Shawn You will blast right past the seals. I will powerwash a tranny the day before I rebuild it, I wrap rags into the stubs, wrap/tape every opening and I still see water in the case when I tear it down. How often do you see people crawl under your car and go "Ohhhhh such a pretty transmission!"?` I guess if you're building a trailer queen it's OK, but I plan to drive my 914. |
bulitt |
Jul 8 2013, 01:56 PM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
(IMG:style_emoticons/default/agree.gif) dont do it, abrasive will get into everything.
Heres a thread- Cleaning up a trans |
Harpo |
Jul 8 2013, 03:01 PM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
The Dr advises against it. I was chastised for cleaning up mine:)
shawn914 |
Jul 8 2013, 04:33 PM
Thanks for responses. Will NOT get it blasted. Regretfully, I did use a power washer for probably less than 5 minutes to knock off some grime. As this was clearly not good, I may have to break this down sooner rather than later.
pcar916 |
Jul 8 2013, 04:43 PM
Water certainly went into the vent if you didn't plug it, and in via the flange seals as well. For now I'd drain/tilt to get as much out as possible and refill. If it was in the car running water will evaporate eventually but out of the car the water will just sit there... sittin'.
ConeDodger |
Jul 8 2013, 04:52 PM
Apex killer! Group: Members Posts: 23,586 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
My 915 was put in a car part 'dishwasher' and then left on a stand for a few months. It looked fantastic! When it was taken apart a few days back there was some surface rust on a few internals. Nothing that will not wipe off but just a thought. I would think the way to do it would be to take it apart and soda blast the external case...
draganc |
Jul 8 2013, 09:50 PM
Senior Member Group: Members Posts: 725 Joined: 2-November 09 From: central new jersey Member No.: 11,000 Region Association: North East States |
I wish my tranny would have looked like yours. Not perfect but not bad at all - from the pics.
I sealed off all the openings and had it soda blasted and washed it afterwards. Came out really nice. |
NORD |
Jul 8 2013, 10:18 PM
Senior Member Group: Members Posts: 1,505 Joined: 14-September 04 From: Lynden Washington Member No.: 2,756 Region Association: Pacific Northwest |
Put mine on a stand and rolled it out on the grass. Used simple Green full strength and. A parts washer stiff brush then rinsed with garden hose. All OK and looks good. |
Lo-Fi Version | Time is now: 14th May 2024 - 11:45 PM |
