Valve Covers, Are they all the same? |
Allan |
Dec 3 2004, 10:48 AM
Are all valve covers the same? 1.7 - 2.0? And are they interchangable from left to right and can they be straightened easily. I have one with the outside lip that is bent.
SLITS |
Dec 3 2004, 11:54 AM
Uh yeah, except for those made with tabs to hold the gaskets - not sure when they started.
Jake Raby |
Dec 3 2004, 11:55 AM
The early 1.7 had different covers. They are a different shape but will still fit a 2.0 head or any other..
They are swappable from left to right.. Install with the vw logo UPSIDE DOWN, thats the right way.. |
Allan |
Dec 3 2004, 12:11 PM
What about repairing these things if they get warped or bent?
Mueller |
Dec 3 2004, 01:06 PM
QUOTE(Headrage @ Dec 3 2004, 11:11 AM) What about repairing these things if they get warped or bent? that depends on you and your skills...might just be better off finding a known good set.... |
Allan |
Dec 3 2004, 01:08 PM
Thanks guys. I don't have the equipment to really ensure that the surfaces are flat and true so I'll post a WTB in the classifieds.
Brando |
Dec 3 2004, 03:15 PM
Might sound like a dumb question, but since we're on the topic of valve covers...
Do the aluminum empi covers with finning on them actually make a difference or no? |
Dec 3 2004, 03:28 PM
Yes, they do. They drastically increase the amount of oil you find on your heat exchangers... Plus they add stress to fasteners that are not very over-engineered in the first place (the rocker arm retaining studs).
IMHO, they suck. --DD |
MattR |
Dec 3 2004, 03:46 PM
QUOTE(Dave_Darling @ Dec 3 2004, 01:28 PM) They drastically increase the amount of oil you find on your heat exchangers... Hmm, more oil on the heat exchangers, eh? (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/biggrin.gif) |
URY914 |
Dec 3 2004, 03:49 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,598 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
No, there are two kinds. Those that leak and those that don't. They look alot alike. As far as the cast aluminim ones, they suck. Paul |
Mike D. |
Dec 3 2004, 04:25 PM
OK, It runs now, and pretty good too! Group: Members Posts: 1,445 Joined: 3-January 03 From: Santa Clarita, Ca Member No.: 85 Region Association: None |
QUOTE(Dave_Darling @ Dec 3 2004, 01:28 PM) Yes, they do. They drastically increase the amount of oil you find on your heat exchangers... Plus they add stress to fasteners that are not very over-engineered in the first place (the rocker arm retaining studs). IMHO, they suck. --DD AND they wont fit under your stock cooling tins without a little help... (IMG:style_emoticons/default/smash.gif) ...the tin that is. -Mike D. BTW - I have three sets of brand new valve covers, Still have the Porsche stickers on them. Not cheep but that is because I paid too much for them (IMG:style_emoticons/default/huh.gif) |
Jake Raby |
Dec 3 2004, 05:13 PM
Stock or nothing..
The bolt on ones have weak hardware that sucks. They can easily pop right off and take the rockers with them.. If you want something nice I sell carbon fiber ones that use stock gaskets and bails and don't leak. |
ChrisFoley |
Dec 3 2004, 06:01 PM
I am Tangerine Racing Group: Members Posts: 7,925 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Some early ones have a rounded countour that interferes with the rocker adjusters when a big cam is used. The later ones have straight sides that give more room inside.
The cast aluminum ones can be modified to not leak. The gasket surface has to be milled, and the flat where the nut goes has to be milled on a 3.5 degree angle, since the rocker stud isn't perpendicular to the gasket surface. Generally speaking, it's not worth the added expense. I think the hardware fails because people overtighten them trying to eliminate the leaks. (IMG:style_emoticons/default/unsure.gif) |
Allan |
Dec 4 2004, 09:56 AM
Thanks again guys. Slits is bailing me out again. (IMG:style_emoticons/default/smilie_pokal.gif)
Lo-Fi Version | Time is now: 16th May 2024 - 12:31 AM |
