My New 1974 1.8, It has issues, please help |
03blueboo |
Jul 9 2013, 01:48 PM
Newbie Group: Members Posts: 31 Joined: 9-July 13 From: Lexington, KY Member No.: 16,108 Region Association: South East States |
Hi Everyone,
I just bought a 1974 1.8. It runs and drives well and I couldn't be happier. Well, mostly couldn't be happier. Here are the issues (I need to resolve them else the car won't pass inspection). The following items aren't working: Reverse Lights, brake lights, wipers, windshield sprayer, horn and possible the interior light. The hand brake moves about 3 inches but won't engage, and it won't engage the brakes either. I checked the bulbs, and all the other lights and signals work. Any suggestions or tips would be appreciated. Thanks Nate |
mrholland2 |
Jul 9 2013, 01:54 PM
Senior Member Group: Members Posts: 750 Joined: 7-September 11 From: Santa Maria,CA Member No.: 13,531 Region Association: Central California |
Before you start getting advice, do two things:
1. Buy a multi-meter 2. Check the weird fuses to make sure they are THERE and that they aren't bad and that they are all making good contact. This seems silly, but the fuses arevery odd in our cars. Sean Hi Everyone, I just bought a 1974 1.8. It runs and drives well and I couldn't be happier. Well, mostly couldn't be happier. Here are the issues (I need to resolve them else the car won't pass inspection). The following items aren't working: Reverse Lights, brake lights, wipers, windshield sprayer, horn and possible the interior light. The hand brake moves about 3 inches but won't engage, and it won't engage the brakes either. I checked the bulbs, and all the other lights and signals work. Any suggestions or tips would be appreciated. Thanks Nate |
03blueboo |
Jul 9 2013, 02:02 PM
[quote name='mrholland2' date='Jul 9 2013, 03:54 PM' post='1892430']
Before you start getting advice, do two things: 1. Buy a multi-meter 2. Check the weird fuses to make sure they are THERE and that they aren't bad and that they are all making good contact. This seems silly, but the fuses arevery odd in our cars. Sean Thanks Sean. I did check the fuses and they all looked good, but I didn't pull them to make sure. I'll pick up the multi-meter though. I'm sure I'll need one again later. Nate |
rick 918-S |
Jul 9 2013, 02:04 PM
Hey nice rack! -Celette Group: Members Posts: 20,456 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
The hand brake handle has a button that is spring loaded and engages a gear when pulled. If the handle doesn't stay up and needs to be released by pressing the button start there. Then move to the cables and rear calipers.
(IMG:style_emoticons/default/welcome.png) |
montoya 73 2.0 |
Jul 9 2013, 02:19 PM
Lack of consideration to others, and Selfish! Group: Members Posts: 1,791 Joined: 27-October 04 From: Paso Robles, Ca. Member No.: 3,016 Region Association: Central California |
So your blinkers blink and your running lights illuminate but no reverse or brake lights? Check your grounds and clean all the contact points for the fuses and bulbs. As Sean said, be sure you have power to the bulb before you start taking things apart. |
03blueboo |
Jul 9 2013, 02:28 PM
Thanks Drew!
montoya 73 2.0 |
Jul 9 2013, 02:35 PM
As a life long VW owner, I like to start cheap and work my way to expensive. Cleaning and checking are free, replacing fuses and bulbs are starting to be expensive. Re-wiring and replacing broken bulb housings are expensive! Good luck!
By the way; (IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif) |
03blueboo |
Jul 9 2013, 05:38 PM
So I checked all the fuses and some are not getting power. But as an update, the brake lights now work. And the hand brake stops the car, it just won't catch so I guess I need to deal with the ratchet.
On the subject of fuses, some of the fuses installed are incorrect. Like, there are several 25a in place of 8a. Not sure if I should be worried. And one headlight likes to wink 3-8times before stowing. I tried to adjust it on the motor with some success but now there is a grinding noise. Any ideas? Nate |
type47 |
Jul 10 2013, 02:41 AM
... windshield sprayer... All the other things on your list are electrical. The washer system has a bottle under the front hood on the passenger's side that receives pressure from the spare tire so as a start, you could verify that the connection between the spare and the bottle is there. Then there are all the connecting rubber hoses ... old rubber, be ready for splits ... The stalk operates a little release valve to provide the spray. So, there is a couple of days work checking all that out (IMG:style_emoticons/default/dry.gif) Check out the link to the electrical diagrams on Pelican and the parts diagrams; links in my signature ... |
Lo-Fi Version | Time is now: 14th May 2024 - 09:04 AM |
