F/S Blau 80mm Oil and 110mm gas cap |
Harpo |
Jul 13 2013, 06:16 AM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
NOS Aluminum ST/RSR NOS Blau oil cap, also used on several other Porsche (race) cars. The caps are 86mm outside diameter and have a cork seal.
It comes with a 1.5 inch fillerneck so you can fab your own ST/RSR filler mouth on your oil tank. (These necks are 80 mm outside diameter) + New Polished Stainless Steel Fuel Cap 110 mm for Centerfiller tank application, thru the hood or under the hood. (New production). Comes with a 100 mm (outside diameter) filler neck of about 3 inches to weld on the fuel tank for an under hood application, or you can extend it to a thru the hood length yourself. $300 shipped in CUSA |
Lo-Fi Version | Time is now: 19th May 2024 - 03:48 AM |
