NOS Aluminum ST/RSR NOS Blau oil cap, also used on several other Porsche (race) cars. The caps are 86mm outside diameter and have a cork seal.
It comes with a 1.5 inch fillerneck so you can fab your own ST/RSR filler mouth on your oil tank. (These necks are 80 mm outside diameter)
New Polished Stainless Steel Fuel Cap 110 mm for Centerfiller tank application, thru the hood or under the hood. (New production). Comes with a 100 mm (outside diameter) filler neck of about 3 inches to weld on the fuel tank for an under hood application, or you can extend it to a thru the hood length yourself.
$300 shipped in CUSA
