-4 dual carb throttle cable routing |
shuie |
Jul 14 2013, 03:20 PM
Member Group: Members Posts: 352 Joined: 17-May 04 From: baton rouge, la Member No.: 2,075 |
What is the best way to route the throttle cable on a dual carb Type IV? I was able to find a few threads where people flipped the carbs and used a stock cable. My engine has a really nicely built bracket for the throttle cable hookup, but I am going to have to route a stock cable up through the front of the engine tin to make it work.
Does someone make a custom cable for a dual Weber setup that will route through the back of the engine tin like the stock throttle cable? Or, should I just route the stock cable up through the front of the tin? TIA |
shuie |
Jul 15 2013, 12:41 PM
Anyone have suggestions other than the backwards carb setup?
michael7810 |
Jul 15 2013, 01:30 PM
Senior Member Group: Members Posts: 1,081 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region |
I use the Tangerine dual carb linkage and the stock cable was too short for my installation. I had to make my own cable from motorcycle shop cable and housing. For the pedal end, I made the attachment from a bolt; cut the head off, drilled the center, then soldered & swaged it on the cable. For the end that attaches to the carbs I melted solder in the cable stands. My finished cable is about 12 inches longer than a stock cable and the routing has nice smooth bends.
Jul 15 2013, 01:45 PM
There is nothing backwards about setting the webers up correctly on a 914 motor.
Using the stock throttle cable, making a custom bracket to hold it off the fan housing, roughly in the middle, but slightly to the passenger side....there is a hole in the fan you can use... Everything lines up perfectly. That is for the worst choice of linkage, the CB performance (or any) cross bar linkage. The next step forward would be the CSP style center pivot linkage which also uses the stock throttle cable on a custom bracket. You can find that from McMark here, or CSP in Germany... The best step, which also uses the stock throttle cable coming from the front, is the Foley cable linkage and setup that will not get out of adjustment and provides smooth control of the throttle. All use the stock throttle cable coming in from the front. Nothing is backwards about any of them. rich |
michael7810 |
Jul 15 2013, 03:06 PM
I mounted the carb pulleys towards the rear of the car because with them on the front (using the stock accel cable) I had to remove the carbs to remove #2 & #4 spark plugs and that was a real PITA. I think my intakes might be too short for the pulley linkage on a 1.7. I don't like having a custom accel cable in case it breaks. I need to make a spare before it happens.
monkeyboy |
Jul 15 2013, 03:19 PM
Senior Member Group: Members Posts: 808 Joined: 8-June 08 From: Los Angeles, Ca Member No.: 9,147 Region Association: None |
Michael, it's the way it goes. Everyone I know that is running the Tangerine linkage had to do a ton of reengineering to make them work.
Mine sit right over the 1 - 3 spark plug boots. |
914werke |
Jan 13 2014, 10:40 AM
"I got blisters on me fingers" Group: Members Posts: 10,072 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
I ran into this issue as well the WE.
Customer car with NO tin in front of fan shroud presumably to allow the OE cable to to route over the top/center of the shroud, where they had fabbed a "bracket" to allow pull over the top of the hex bar. To install the correct bracket (like the one Mark & other sell) It looks like I have to remove & flip the carbs to mount them so the linkage is in back? |
ChrisFoley |
Jan 13 2014, 12:48 PM
I am Tangerine Racing Group: Members Posts: 7,926 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I use the Tangerine dual carb linkage and the stock cable was too short for my installation. I had to make my own cable from motorcycle shop cable and housing. For the pedal end, I made the attachment from a bolt; cut the head off, drilled the center, then soldered & swaged it on the cable. For the end that attaches to the carbs I melted solder in the cable stands. My finished cable is about 12 inches longer than a stock cable and the routing has nice smooth bends. We made sure the stock cable would reach any of the 4 possible locations before selling one kit. If you couldn't reach, you must have not relocated the cable properly. Our original kits had potential clearance issues with spark plug wires when short manifolds are used. Our recently revised kits have cured that problem. |
914werke |
Jan 13 2014, 03:29 PM
So it there an "appropriate" direction for mounting the carb bodies?
Or is is just up to every individual? |
Lo-Fi Version | Time is now: 19th May 2024 - 03:48 AM |
