Porscharu73 |
Member ![]() ![]() Group: Members Posts: 88 Joined: 24-December 12 From: Clovis ca Member No.: 15,281 Region Association: None ![]() |
Hello 914 world and welcome to my thread ....I'm in the process of a conversion with a ez30r I have been collecting parts since december of 2012 its going to be a long road ahead but I see the promise land ahead
![]() Here she is one long search 10 hour drive and a trade later she is mine (IMG:style_emoticons/default/biggrin.gif) bodywork was all done prior and anti rust agent was done by last owner ![]() |
Porscharu73 |
![]() I love my girls with a fat a$$ (IMG:style_emoticons/default/KMA.gif) lol ![]() I enjoy art so I was having a pow wow to myself in the garage and pick up a pencil lol (IMG:style_emoticons/default/idea.gif) have yet to finish So my first thought was to go with a jdm ej20 forged pistons bigger injectors the works but with a stock td04 I was going for reliability for trips and driving around town run low boost 8-10 psi a little more when I wanted to really get on it. Well after a little bit more research I started to fall for the ez30r just everything about it seem to please me a bit more and seeing people here have done it already and a heated debate to myself v6 or 4 banger turbo I decided to scrap the ej20 idea and purchase the ez30 instead |
Porscharu73 |
![]() I picked up the motor for Just under 1400 with automatic trans from a local Jdm engine dealer Note this is not my motor I had pictures of it fully assemble and then pics of it after torn it down but I lost them all when I lost my phone (IMG:style_emoticons/default/sad.gif) but you get the idea and will post pics of my motor soon ![]() Here is the 03 Wrx 5 speed I will be using that I picked up for $50 in Lancaster CA the guy said there was no 2nd gear we will find out |
Porscharu73 |
![]() At the same time that day of picking up the trans I had a family member pickup a 1989 sc 911 complete front suspension for $500 in sac for me THANKS for good family now for some wheels soon I hope lol ![]() So after some long research and calling and asking questions on radiators I decided to go with one I found that's duel core duel pass 24x9 with an-16 bungs on it i will have to make my own shroud well using dual 8 inch spal fansI picked up all my fittings from jegs and sniper motorsports with high gloss finish with pro-flo 350 light weight racing hose this includes my water fuel and oil I have a lot more fitting just didn't get them in the picture |
Porscharu73 |
So this is where I have stop in the mean time I'm in the process of looking up a ecu maybe a link g4 xtreme or stinger 6860 also looking into some magic flanges or another option to cvs, the shifter and linkage and cradle once I figure this out I will start the build of putting everything together but I'm really close and can't wait to start I will post more pictures and chime in when ever I get the chance right now work and funds are getting in the way hopefully to finish by October for a trip up and down the California coast line as of now my goal is a reliable driver after all said and done I plan on turbocharging the ez30 (IMG:style_emoticons/default/piratenanner.gif)
So feel free to chime in and thanks for looking Also if anyone knows of the specs that this conversion gives out 0-60 times,weight,mpg,things of that nature would be greatly appreciate (IMG:style_emoticons/default/bye1.gif) |
Porscharu73 |
JRust |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,317 Joined: 10-January 03 From: Albany Oregon Member No.: 129 Region Association: Pacific Northwest ![]() ![]() |
Get some longer studs. The offset on those won't be right. I'm going to guess you'll need 1" to 1"1/2 up front. Then 1"1/2-2 1/2" in back. I'll hope I am wrong there but I looked at a set once. Much deeper offset
Andyrew |
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,380 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California ![]() ![]() |
bulitt |
Achtzylinder ![]() ![]() ![]() ![]() Group: Members Posts: 4,189 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States ![]() |
Good luck on your project! Have Fun!
Just install the 100mm studs on the 911 hubs then you can cut off the excess down the road after everything has been fitted. The radiator looks a tad small to me ??? |
Randal |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 ![]() |
At the same time that day of picking up the trans I had a family member pickup a 1989 sc 911 complete front suspension for $500 in sac for me THANKS for good family now for some wheels soon I hope lol So after some long research and calling and asking questions on radiators I decided to go with one I found that's duel core duel pass 24x9 with an-16 bungs on it i will have to make my own shroud well using dual 8 inch spal fansI picked up all my fittings from jegs and sniper motorsports with high gloss finish with pro-flo 350 light weight racing hose this includes my water fuel and oil I have a lot more fitting just didn't get them in the picture Just a heads up on that light weight hose. I used it up front with my oil cooler and all it needs is one little thread cut or tear (just rubbing somewhere) and it will fail shortly after. What happens is that the thread unravels a bit from where ever it is cut or torn, then that spot isn't protected against pressure and it blows the hose. I I had mine fail at an autox and it dumped 2 quarts of oil so fast you wouldn't believe it. So use the stainless steel wrapped stuff, or you'll be retrofitting like I had to do. (IMG:style_emoticons/default/biggrin.gif) |
Porscharu73 |
![]() This is the radiator I'm using its for Hondas it's a tucked radiator for the Hondas running big turbos or in need of extra room I call them and talk to them they said it should be able to do just fine for what I'm using it for look a perrins build and many other ez30r conversions even when they turbo charge the motor they still us the stock ez30 radiator As far as the hose im was thinking of using that hose shield don't really know what it is called ...and I'm will be metal piping with -16an bungs welded to it for under the car but completely understand where your coming from As far as the 100mm studs thanks I will be looking into them will spacers be necessary |
3d914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,275 Joined: 24-September 03 From: Benson, AZ Member No.: 1,191 Region Association: Southwest Region ![]() |
Cool project! Looks like the kit was done well. I like the front bumper on that Rayco kit. Good choice for motor, too! EZ30 was on my list - just wasn't brave enough to venture that deeply into the unknown at the time. I started mine in 2008.
bulitt |
Yes spacers will be needed for those wheels.
Porscharu73 |
Porscharu73 |
Porscharu73 |
Porscharu73 |
Mike Bellis |
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,347 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None ![]() ![]() ![]() |
Your coolant lines look nice. You better raise your car up high! You will rip the lines open after a few speed bumps. I've lost count on how many times my rubber lines have hit bumps...
You could fab skid plates to protect the lines. (IMG:style_emoticons/default/idea.gif) Looks like a cool build... (IMG:style_emoticons/default/smile.gif) |
JRust |
Your coolant lines look nice. You better raise your car up high! You will rip the lines open after a few speed bumps. I've lost count on how many times my rubber lines have hit bumps... You could fab skid plates to protect the lines. (IMG:style_emoticons/default/idea.gif) Looks like a cool build... (IMG:style_emoticons/default/smile.gif) That is the nice thing with the gates greens tripe hose. Tough enough can just flex with a bump. so even if it's smashed by a bump. Typically it is just temporary. That does look nice & clean. Can't wait to see you fire that up (IMG:style_emoticons/default/piratenanner.gif) . Keep up the good work |
Porscharu73 |
update
I have still been looking into axles and shifter then came across these rims when I had to pick them up just completes the look very happy how it came out |
Lo-Fi Version | Time is now: 4th July 2025 - 09:18 AM |
