Hero GoPro 3, Good solution? |
Randal |
Jul 18 2013, 08:53 AM
I'm getting really tired sending my little Nikon camera back to LA to have it repaired. It works fine for video, but then it won't open, probably because the car is stiff and likely is causing the gears that open the lens to jam. So was looking at the Hero GoPro3, but was hopeful that people on this board would have opinions on the unit. My use is primarily for Autoxing so would really like something that can be turned on easily, unlike the Nikon which requires someone outside the car to get it started. Sound quality is important as well. Or maybe there is a nice video unit out there that works better. All advice appreciated. |
BKLA |
Jul 18 2013, 09:00 AM
Really old member Group: Members Posts: 1,253 Joined: 14-August 05 From: OR Member No.: 4,590 Region Association: Pacific Northwest |
Very easy to use, mount and play with.
DO IT!!!! |
carr914 |
Jul 18 2013, 09:19 AM
Racer from Birth Group: Members Posts: 118,232 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
I've got a GoPro3 Black. I haven't had a Need to use the Remote yet, but I'm sure I will. I have a Number of Mounts - Suction, RollBar, Hard Mounts. I also bought the Tethers, but haven't used them yet either
Is your Nikon a CoolPix L1? I haven't used it in a car, but I'm having the same problem with it not opening |
nolift914 |
Jul 18 2013, 09:37 AM
Autoxer Group: Members Posts: 183 Joined: 24-May 09 From: Rockaway Beach NY Member No.: 10,399 Region Association: None |
Go with the GoPro, I have the 1st gen which is great, I am sure the hero3 is better!
Randal |
Jul 18 2013, 09:40 AM
I've got a GoPro3 Black. I haven't had a Need to use the Remote yet, but I'm sure I will. I have a Number of Mounts - Suction, RollBar, Hard Mounts. I also bought the Tethers, but haven't used them yet either Is your Nikon a CoolPix L1? I haven't used it in a car, but I'm having the same problem with it not opening It's a CoolPix S4100. The lens opening mechanism is actually pretty nice, but thinking it's not designed for the way I'm using it! (IMG:style_emoticons/default/biggrin.gif) I mean what else is new? |
jpnovak |
Jul 18 2013, 04:20 PM
They call me "Nanoman" Group: Members Posts: 231 Joined: 26-August 09 From: Austin TX Member No.: 10,736 Region Association: Southwest Region |
I have a Contour GPS. Really like the adustable gain to prevent wind noise. Great picture quality. Just as easy to mount as the GoPro. Probably less marketing.
okieflyr |
Jul 18 2013, 06:51 PM
9fauxteen Group: Members Posts: 816 Joined: 9-January 05 From: Phila PA Member No.: 3,426 Region Association: North East States |
I got one this summer and like it. It does use up the standard battery pretty quick, 5-6 auto-x runs should be fine. I added the bigger battery and really enjoy the I-phone interface. I just trust the phone remote because I can see the video is on for confirmation. It allows for full semi-real time viewing (1-2 second delay) and programming. I've not found any volume adjustment yet so it 's either on or off during filming at this point unless I find otherwise. Don't skimp on card quality.
Jul 18 2013, 07:14 PM
914-6 GT in waiting Group: Members Posts: 19,244 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I've sold hundreds of go pros at the ski shop. they are the camera to get. many options and are the leader of the industry. You must use a high quality card. many people have multiple cards and batteries. smart phone and wireless remote are just icing on the cake.
brant |
Jul 19 2013, 06:49 AM
914 Wizard Group: Members Posts: 11,615 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
The go pro doesn't sync up automatically with track mate. So if that is a future upgrade you intend you might look elsewhere. I don't know if the 3 has good sound. It probably takes an external mic which could be an added expense.
Andyrew |
Jul 19 2013, 02:26 PM
I have a Gopro 1 1080p and a gopro2.
I dont see much need for a gopro 3 for most uses, the gopro 2 IMHO is better than the 1 in quality a hair but in the fact you can put a mic on it and pull sound from anywhere. I've ran a $5 non amplified mic to a 20ft line and had no distortion in sound quality. |
wndsrfr |
Jul 19 2013, 06:26 PM
Senior Member Group: Members Posts: 1,428 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
It's a CoolPix S4100. The lens opening mechanism is actually pretty nice, but thinking it's not designed for the way I'm using it! (IMG:style_emoticons/default/biggrin.gif) I mean what else is new? I ran across a good tip for a balky lens opening mechanism on the small digital cameras.....the tiniest bit of dust will cause the problem.......so, just put your vacuum cleaner house up to it & cycle it....works wonders. |
Jul 19 2013, 07:35 PM
Get the 3 Black.
Randal |
Jul 19 2013, 11:29 PM
I have a Gopro 1 1080p and a gopro2. I dont see much need for a gopro 3 for most uses, the gopro 2 IMHO is better than the 1 in quality a hair but in the fact you can put a mic on it and pull sound from anywhere. I've ran a $5 non amplified mic to a 20ft line and had no distortion in sound quality. Where do you get that $5.00 mic and cable? Tks. |
Randal |
Jul 19 2013, 11:32 PM
It's a CoolPix S4100. The lens opening mechanism is actually pretty nice, but thinking it's not designed for the way I'm using it! (IMG:style_emoticons/default/biggrin.gif) I mean what else is new? I ran across a good tip for a balky lens opening mechanism on the small digital cameras.....the tiniest bit of dust will cause the problem.......so, just put your vacuum cleaner house up to it & cycle it....works wonders. I'll try that, thanks. But I'm going to get a more rugged video camera. Annoying when you make a good run on a hillclimb and find that the camera is broken. (IMG:style_emoticons/default/smash.gif) |
grantsfo |
Jul 23 2013, 11:44 PM
Arrrrhhhh! Group: Members Posts: 4,327 Joined: 16-March 03 Member No.: 433 Region Association: None |
I'm getting really tired sending my little Nikon camera back to LA to have it repaired. It works fine for video, but then it won't open, probably because the car is stiff and likely is causing the gears that open the lens to jam. So was looking at the Hero GoPro3, but was hopeful that people on this board would have opinions on the unit. My use is primarily for Autoxing so would really like something that can be turned on easily, unlike the Nikon which requires someone outside the car to get it started. Sound quality is important as well. Or maybe there is a nice video unit out there that works better. All advice appreciated. I just picked up this Sony for a little over $200. WiFi, Zeiss lens, slow motion, imagine stabilzer, easy to use. (IMG:http://www.914world.com/bbs2/uploads_offsite/lh6.googleusercontent.com-433-1374644675.1.JPG) |
Andyrew |
Jul 24 2013, 09:26 AM
I have a Gopro 1 1080p and a gopro2. I dont see much need for a gopro 3 for most uses, the gopro 2 IMHO is better than the 1 in quality a hair but in the fact you can put a mic on it and pull sound from anywhere. I've ran a $5 non amplified mic to a 20ft line and had no distortion in sound quality. Where do you get that $5.00 mic and cable? Tks. Ebay. Non amplified mics. Lets see.. http://www.ebay.com/sch/i.html?_trksid=p20...0&_from=R40 and http://www.ebay.com/sch/i.html?_odkw=10FT+...on&_sacat=0 (I got this one) http://www.ebay.com/itm/Mini-High-power-Mi...=item35c9ea6351 |
mskala |
Jul 24 2013, 05:14 PM
Go for:
Small Lightweight No moving parts if you want it to last in a high-vibration environment. I've been a big fan of the bullet cams, haven't had any problems in 10 years. Separate recorder, put it near you if no remote control to turn it on/off. Of course probably none of this exists for HD. |
ConeDodger |
Jul 24 2013, 08:14 PM
Apex killer! Group: Members Posts: 23,569 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
I have two of them. Perfect! (IMG:style_emoticons/default/aktion035.gif)
McMark |
Jul 25 2013, 12:36 AM
Cambo made a vid, for reference. I think the 3 has two lens angles if that looks too wide-angle.
Thread |
Randal |
Jul 25 2013, 04:12 PM
I have a Gopro 1 1080p and a gopro2. I dont see much need for a gopro 3 for most uses, the gopro 2 IMHO is better than the 1 in quality a hair but in the fact you can put a mic on it and pull sound from anywhere. I've ran a $5 non amplified mic to a 20ft line and had no distortion in sound quality. Where do you get that $5.00 mic and cable? Tks. Ebay. Non amplified mics. Lets see.. http://www.ebay.com/sch/i.html?_trksid=p20...0&_from=R40 and http://www.ebay.com/sch/i.html?_odkw=10FT+...on&_sacat=0 (I got this one) http://www.ebay.com/itm/Mini-High-power-Mi...=item35c9ea6351 Tks for the info. |
Lo-Fi Version | Time is now: 28th April 2024 - 10:01 PM |
