914-6 oil tank? |
914-6 oil tank? |
chad newton |
Jul 22 2013, 08:55 PM
Member Group: Members Posts: 110 Joined: 26-August 11 From: behind the red curtain Member No.: 13,491 Region Association: None |
Ok, I am new to anything porsche and I was wondering on my conversion I am going to be doing why do I need to stick with a factory oil tank? I wouldn't mind going to some aftermarket one that holds more oil to begin with. If someone could help, what options do I have? Is there one I can use that is alittle cheaper then factory? I am not looking to do a 914-6 recreation, I am basically building a track car that can still function as a street car. The oil cooler is just the beginning of my million questions I will probably be picking guys brains with. Thankyou.
sixnotfour |
Jul 22 2013, 08:59 PM
914 Wizard Group: Members Posts: 10,432 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Jeffs9146 |
Jul 22 2013, 11:22 PM
It's not the stock tank, it is a tank in the stock location that makes the conversion more ideal for a street car. But for a track car you can put it where ever you want, so it doesn't matter what it looks like!
Here is my nonstock tank in the stock location! You can see the filler neck in the stock location! |
Elliot Cannon |
Jul 23 2013, 12:11 AM
My non-stock tank that will someday, sometime be installed in the stock location to provide oil for a six of some size and HP that maybe someday will more than likely be installed in my car some day. Soon. Maybe. In all likelihood. But not next week almost for sure.
type47 |
Jul 23 2013, 04:44 AM
this link to a thread about an oil tank group buy shows alot of your options and discussion:
http://www.914world.com/bbs2/index.php?sho...+tank+group+buy or enter "914-6 oil tank" including quotes into Search of Garage for a bunch of related threads |
brant |
Jul 23 2013, 06:02 AM
914 Wizard Group: Members Posts: 11,624 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
More info. A tank in the rear trunk is the wrong direction to move weight for balance and handling. A front roundy tank requires large return lines to the motor which eat into any cost savings. Also the front tank isn't legal for some vintage clubs (mine)
GeorgeRud |
Jul 23 2013, 06:33 AM
Don't have any pictures, but I have seen some where a round tank was mounted in the area of the battery box when the battery was relocated.
Woody |
Jul 23 2013, 08:00 AM
Sandbox Rabblerouser and head toilet scrubber Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region |
Cap'n Krusty |
Jul 23 2013, 08:30 AM
Again, putting all that weight high up is a bad thing for handling. The battery box is as high as the trunk floor, more or less, and putting 20-25 pounds up there is gonna be noticeable, especially if you move the battery to a point equally high in the chassis.
The Cap'n |
chad newton |
Jul 23 2013, 09:21 AM
I have already relocated my battery up front so I am guessing that it wouldn't kill me to put a cooler where the battery is supposed to be. But up front seems ok especially if I have to run a cooler. I may fab up something in the battery spot, I guess I can always move it.
Woody |
Jul 23 2013, 07:22 PM
Again, putting all that weight high up is a bad thing for handling. The battery box is as high as the trunk floor, more or less, and putting 20-25 pounds up there is gonna be noticeable, especially if you move the battery to a point equally high in the chassis. The Cap'n Thanks Cap. I was thinking if I take out the tray and run the tank as low as possible it would be comparable to the OEM setup. Guess this may not work as well as I thought. I'm torn between running a tank in the factory location or running a front tank. I am not comfortable having the oil supply all the way up front but I also don't need anymore weight on the driver side. Decisions decisions. (IMG:style_emoticons/default/idea.gif) |
worn |
Jul 23 2013, 09:04 PM
can't remember Group: Members Posts: 3,156 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
My non-stock tank that will someday, sometime be installed in the stock location to provide oil for a six of some size and HP that maybe someday will more than likely be installed in my car some day. Soon. Maybe. In all likelihood. But not next week almost for sure. Hi Elliott, Sorry about the concurrent thread. I wanna learn how to tig that tank. I have the metal, now I have to figure out how to do the baffles. The tig is new tome, but the bending should go ok. Mind if I keep an eye on your photo? Also this is another possible option. If I pull it off either the welder or the tank is free. |
sixnotfour |
Jul 24 2013, 08:36 AM
More info. A tank in the rear trunk is the wrong direction to move weight for balance and handling. A front roundy tank requires large return lines to the motor which eat into any cost savings. Also the front tank isn't legal for some vintage clubs (mine) Don't tell 911 owners this..rear engine ?? |
brant |
Jul 24 2013, 08:43 AM
More info. A tank in the rear trunk is the wrong direction to move weight for balance and handling. A front roundy tank requires large return lines to the motor which eat into any cost savings. Also the front tank isn't legal for some vintage clubs (mine) Don't tell 911 owners this..rear engine ?? That's why we are more balanced than them. Just not mentally. |
ConeDodger |
Apex killer! Group: Members Posts: 23,588 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
More info. A tank in the rear trunk is the wrong direction to move weight for balance and handling. A front roundy tank requires large return lines to the motor which eat into any cost savings. Also the front tank isn't legal for some vintage clubs (mine) Don't tell 911 owners this..rear engine ?? (IMG:style_emoticons/default/agree.gif) Really good driving schools sometimes split participants into groups. "Front drive cars over here, rear drive cars over here, and Porsche 911 drivers over here." When the laughter stops, they explain that front drive cars will behave in a certain way as will rear drive cars, but 911's are likely to do anything! |
Mark Henry |
Jul 24 2013, 01:02 PM
My non-stock tank that will someday, sometime be installed in the stock location to provide oil for a six of some size and HP that maybe someday will more than likely be installed in my car some day. Soon. Maybe. In all likelihood. But not next week almost for sure. Hi Elliott, Sorry about the concurrent thread. I wanna learn how to tig that tank. I have the metal, now I have to figure out how to do the baffles. The tig is new tome, but the bending should go ok. Mind if I keep an eye on your photo? Also this is another possible option. If I pull it off either the welder or the tank is free. Pretty sure that Elliot didn't make that tank (IMG:style_emoticons/default/smile.gif) It's a DWD, same as Patrick MS sells. I did all the research, thought about welding up a steel tank, thought about making an AL tank, thought about a front tank....etc. In the end I was watching the classifieds and I picked up a new DWD tank at a OK price. IMHO just close your eyes, stick your fingers in your ears, start screaming LA-LA-LA-LA-LA....and hit the buy it now button on a DWD tank. |
Elliot Cannon |
Jul 24 2013, 03:55 PM
My non-stock tank that will someday, sometime be installed in the stock location to provide oil for a six of some size and HP that maybe someday will more than likely be installed in my car some day. Soon. Maybe. In all likelihood. But not next week almost for sure. Hi Elliott, Sorry about the concurrent thread. I wanna learn how to tig that tank. I have the metal, now I have to figure out how to do the baffles. The tig is new tome, but the bending should go ok. Mind if I keep an eye on your photo? Also this is another possible option. If I pull it off either the welder or the tank is free. Pretty sure that Elliot didn't make that tank (IMG:style_emoticons/default/smile.gif) It's a DWD, same as Patrick MS sells. I did all the research, thought about welding up a steel tank, thought about making an AL tank, thought about a front tank....etc. In the end I was watching the classifieds and I picked up a new DWD tank at a OK price. IMHO just close your eyes, stick your fingers in your ears, start screaming LA-LA-LA-LA-LA....and hit the buy it now button on a DWD tank. WHAT?? How DARE you question my welding skills? (IMG:style_emoticons/default/welder.gif) Actually, I bought that tank from these guys. I'm not sure but don't think they have any left. (And it wasn't cheap). (IMG:style_emoticons/default/biggrin.gif) http://rebelracingproducts.com/index.html |
ConeDodger |
Jul 24 2013, 04:12 PM
Elliot's is a DW Design tank. I'm not sure the PMS tank is the same or if PMS just started making them on their own.
brant |
Jul 24 2013, 06:31 PM
I have a home made aluminum tank. I copied the stock tank. It is very similar to the one above. I am on a phone or else could post a link. My thread has baffle pictures too
brant |
Jul 24 2013, 06:32 PM
Lo-Fi Version | Time is now: 17th May 2024 - 08:58 PM |
