removing undercoating, using heat gun |
RFoulds |
Jul 22 2013, 10:18 PM
Green Teen 66 Group: Members Posts: 837 Joined: 10-August 09 From: La Quinta, CA Member No.: 10,656 Region Association: Southwest Region |
Finally got back to work on Willow Green. Removing aftermarket undercoating today. Here is one wheel well.
Heat gun, putty knife, gloves, mask. (IMG:http://www.914world.com/bbs2/uploads_offsite/img.photobucket.com-10656-1374553102.1.jpg) Before (IMG:http://www.914world.com/bbs2/uploads_offsite/img.photobucket.com-10656-1374553103.2.jpg) During (IMG:http://www.914world.com/bbs2/uploads_offsite/img.photobucket.com-10656-1374553105.3.jpg) After (IMG:http://www.914world.com/bbs2/uploads_offsite/img.photobucket.com-10656-1374553105.4.jpg) |
RFoulds |
Jul 22 2013, 10:19 PM
Some nooks and crannies to clean up, some spots to rub out, then touch up.
JeffBowlsby |
Jul 22 2013, 10:44 PM
914 Wiring Harnesses Group: Members Posts: 8,509 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Coming along nice...how much time did the one wheel well take? Have you used any solvent on it yet - like paint thinner?
RFoulds |
Jul 22 2013, 11:13 PM
Hi Jeff. One wheel well took about 2.5 hours. I used solvent for first cleaning, and then solvent with 00 steel wool after the heat gun
rhodyguy |
Jul 23 2013, 07:10 AM
you might try/buy some of this stuff for after the heat gun. not too stinky, you load/spray it from a spray bottle, let it work and the residue wipes off with scotchbrite pads and paper towels, and you de-activate with alcohol. down side is it will lift the paint. i used it on floor tar. great stuff. seems spendy but it goes a long way. my powdercoater uses it.
Attached thumbnail(s) |
RFoulds |
Jul 23 2013, 11:10 AM
I have used similar products. I don't want to strip the paint underneath. The point here is to reveal the paint that has been protected by the soft tar based undercoating. Just like on my Oly Blue when I stripped off the original Cosmoline. Getti g a car back to the "as delivered to dealer" look.
mr914 |
Jul 23 2013, 09:10 PM
914 Hillbilly Group: Members Posts: 576 Joined: 11-January 03 From: Lincoln NE Member No.: 131 Region Association: None |
The best stuff I found is the POR-15 stripper
The undercoat/paint/sealer laughed (IMG:style_emoticons/default/hissyfit.gif) at the aviation strippers. Even with plastic wrap, etc. hours and hours, heat and scrape and it wouldn't come off. 70 914-6. Bought a jug of this stuff and it was done in a couple of hours (IMG:style_emoticons/default/cheer.gif) |
Matt Romanowski |
Jul 23 2013, 09:17 PM
Senior Member Group: Members Posts: 878 Joined: 4-January 04 From: Manchester, NH Member No.: 1,507 |
I've done a number of cars with kerosene. Spray on from a spray bottle, let soak for 30 minutes, scrape off with a plastic putty knife and scrub with various brushes. Works great.
RFoulds |
Jul 25 2013, 10:45 AM
I have used kerosene previously but the heat gun is proving to be more thorough. then a light scrub with Mineral spirits and steel wool.
Process would have been easier but I decided not to remove struts. Mainly because they still had factory seal marks. Am I being too anal? (IMG:http://www.914world.com/bbs2/uploads_offsite/img.photobucket.com-10656-1374770710.1.jpg) |
Lo-Fi Version | Time is now: 17th May 2024 - 02:17 PM |
