Gaskets for HE duct parts |
lsintampa |
Jul 23 2013, 08:16 PM
Senior Member Group: Members Posts: 520 Joined: 28-January 13 From: Tampa, FL Member No.: 15,441 Region Association: South East States |
The covers that go over the flappers on the fan shroud, what are they made of?
Ditto for the clamps that hold the duct work to the HEs. I assume it's the same stuff. Just curious what you all are using for gaskets? Thanks, Len |
SLITS |
Jul 23 2013, 10:21 PM
The gaskets were built/glued into the tin. Never heard of a source for the material ... probably cork.
I installed mine without the gaskets ... didn't seal shit anyway. |
type47 |
Jul 24 2013, 05:08 AM
michael7810 |
Jul 24 2013, 05:19 AM
Senior Member Group: Members Posts: 1,081 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region |
I didn't use gaskets and it doesn't seem to be a problem. Plenty of heat for Phoenix winters.
lsintampa |
Jul 24 2013, 07:06 AM
Yeah, I saw that on their site, so I thought to myself, someone other than me wants to seal that thing, but is stubborn enough to refuse to pay for what looks to be a piece of cork. I have cork gasket material and can make my own. Just was wondering if the material needed to be something more heat resistant. As a side, I fine many parts on AA to be on the high side. I guess when you have a captive audience higher prices is one of the things that come with. |
ripper911 |
Jul 24 2013, 07:15 AM
corde pulsum tangite Group: Members Posts: 2,920 Joined: 25-April 10 From: Powder Springs, GA Member No.: 11,654 Region Association: South East States |
Not exactly cork, but it kinda has a similar feel. Looks like it's a more heat resistant material.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i921.photobucket.com-11654-1374671749.1.jpg) |
lsintampa |
Jul 24 2013, 07:24 AM
Not exactly cork, but it kinda has a similar feel. Looks like it's a more heat resistant material. Yeah, but AA even calls it cork on their site. Is your gasket OEM? Cause it looks like the AA gasket is cork and they call it as such. In any event, I'm all about forming my own since I already have a sheet of cork material on hand. |
ripper911 |
Jul 24 2013, 07:28 AM
I am inside of AA right now, I grabbed that one off of the shelf and took a picture just for you.
It's the genuine Porsche part. |
lsintampa |
Jul 24 2013, 07:29 AM
ripper911 |
Jul 24 2013, 07:41 AM
Just because it's the morning...
Here's a picture of a bag of them in front of the 916. (IMG:style_emoticons/default/beerchug.gif) (IMG:http://www.914world.com/bbs2/uploads_offsite/i921.photobucket.com-11654-1374673282.1.jpg) They're some kind of dark corky material. |
rhodyguy |
Jul 24 2013, 08:06 AM
on the cheap. the branch ducting clamping pieces can be sealed by making a small bead of rtf on the ducting side where the clamping pieces make contact. let the bead set up to the point where the rtv is fully cured. or not. you're not going to lose that much air flow without gaskets.
Cap'n Krusty |
Jul 24 2013, 08:59 AM
The original gaskets appear to be some kind of compressed paper-like material, something along the lines of the original thick sump gaskets.
The Cap'n |
sean_v8_914 |
Jul 24 2013, 09:03 AM
autozone and summit racing sells a roll of that thick press paper like gasket material. its tough to cut. i used a razor. be careful, you have to push hard and if it lets go, look out!
Bartlett 914 |
Jul 24 2013, 09:08 AM
I used an o-ring. You can use rubber cord stock. Not perfect but it worked
Mikey914 |
Jul 24 2013, 09:21 AM
The rubber man Group: Members Posts: 12,669 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Hummmmm..............
lsintampa |
Jul 24 2013, 09:25 AM
The original gaskets appear to be some kind of compressed paper-like material, something along the lines of the original thick sump gaskets. The Cap'n I got some of that laying around here also. It isn't that big of a deal, I'm in FL, so heat isn't an issue. It may however be an issue for the next owner - should there be one. (IMG:style_emoticons/default/unsure.gif) |
lsintampa |
Jul 24 2013, 09:33 AM
Just because it's the morning... Here's a picture of a bag of them in front of the 916. (IMG:style_emoticons/default/beerchug.gif) They're some kind of dark corky material. To be honest, I'm not shocked to see a bag of them. The other side is like $45.00 so for both gaskets, cork or whatever they are made of, you're up near $80.00. Almost the cost for a low end carpet set for the car, more than a set of brake pads, and so on... is another way to look at it. Thanks! |
walterolin |
Jul 24 2013, 09:50 AM
Senior Member Group: Members Posts: 685 Joined: 30-November 11 From: Louisville, Ky Member No.: 13,838 Region Association: South East States |
Your department, Mark. I'll need a set when I start to reassemble.
The old stuff I took off of mine looked more like a heat resistant material such as asbestos (now verboten). I think I would want something a little better than cork. Gasket material or RTV as suggested above would probably be sufficient. Hummmmm.............. |
ChrisFoley |
Jul 24 2013, 11:08 AM
I am Tangerine Racing Group: Members Posts: 7,925 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
This is what I use.
http://www.mcmaster.com/#5109K21 1/4" wide silicone strip with adhesive backing. $12 for a 15ft length, enough for quite a few cars. |
Lo-Fi Version | Time is now: 17th May 2024 - 05:15 PM |
