SCCA rules, rule out big bore motors |
Randal |
Jul 26 2013, 09:59 AM
At least in XP.
A fantasy of mine is to keep my car all Porsche and put in a 993 3.6. While the car would be +/-100 pounds heaver it would have over 300hp (with Varioram) and around 250lbs of torque. It would be a great hill climb car able to compete with the big bore modified cars. OK, but then what do you do the rest of the year? XP rules would dictate ballasting up to 1997#. Are you kidding me? So the only way to be competitive in XP is to convert to a Suby or shove in a twin turbo motor, just like everyone else. Annoying. |
brant |
Jul 26 2013, 11:53 AM
914 Wizard Group: Members Posts: 11,614 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
The 911 conversion adds a bit over 150lbs from a 4.
Randal |
Jul 26 2013, 12:11 PM
The 911 conversion adds a bit over 150lbs from a 4. Ouch! I could lose another 50lbs off my car pretty easily, so 1800# would be the target finished weight. So 1800# (excluding driver) with over 300hp and 270+ foot pounds of torque. For a car that handles that would be a pretty good package. Personally I don't care about the HP, it's the torque that moves the car out of the corners. |
Woody |
Jul 26 2013, 12:16 PM
Sandbox Rabblerouser and head toilet scrubber Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region |
I have begun to source some parts to build a short stroke 2.5 off of a 74 7R case. Displacement will be 2519 and I will be running in FP. I don't think I will have much problems keeping the car under 1900 lbs.
Randal |
Jul 26 2013, 12:22 PM
grantsfo |
Jul 26 2013, 01:10 PM
Arrrrhhhh! Group: Members Posts: 4,327 Joined: 16-March 03 Member No.: 433 Region Association: None |
Could always run EM. Even with turbo you'd have to ballast up. Then you have Driveability issues associated with low displacement turbo motor.
Woody |
Jul 26 2013, 01:27 PM
I'm hoping to see 220+ hp and 175 ftlbs but the torque may be a bit on the optimistic side. I intend to build it with a very light rotating mass and use a non counterweighted 2.0 crankshaft with E cams. I would like to have a 8,000 rpm redline and gear the car low. I think this could work if I keep the car light. Granted I am just now beginning to aquire the parts needed and have no idea how I am going to be able to afford everything. Buying a 3.2 or a 3.6 would be cheaper but I already have the 2.7.
brant |
Jul 26 2013, 02:44 PM
I have begun to source some parts to build a short stroke 2.5 off of a 74 7R case. Displacement will be 2519 and I will be running in FP. I don't think I will have much problems keeping the car under 1900 lbs. Under 1900 with a 6 is doable but not easy. Review my thread about how we got to 1826. Don't expect to have any street legal gear (no headlights or windows for instance). An enclosed trailer becomes necessary for long tows through rain. Most -6 cars are 2000lbs at road racing trim |
Woody |
Jul 26 2013, 06:16 PM
I have begun to source some parts to build a short stroke 2.5 off of a 74 7R case. Displacement will be 2519 and I will be running in FP. I don't think I will have much problems keeping the car under 1900 lbs. Under 1900 with a 6 is doable but not easy. Review my thread about how we got to 1826. Don't expect to have any street legal gear (no headlights or windows for instance). An enclosed trailer becomes necessary for long tows through rain. Most -6 cars are 2000lbs at road racing trim I read your thread. Great build. I intend to keep it street legal but am willing to go with glass lids and plexi windows. As for headlights I will probably fab up some sort of GT like kit. |
Jul 26 2013, 06:18 PM
Custom Member Group: Members Posts: 24,565 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Twin turbo 3.6
Just saying |
brant |
Jul 26 2013, 06:29 PM
Street legal is going to be closer to 1950 -2000lbs. Let us know when you weigh. I've been doing this for 25 years and 1900 will be tough if street legal.
Let us know. |
Britain Smith |
Jul 26 2013, 11:23 PM
Nano Member Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 |
I was sub-1800 with a 2.7L 6-cylinder motor...and that was with a overly heavy cage.
-Britain |
brant |
Jul 27 2013, 05:12 AM
Yes but not street legal. My car is a bit heavy because of the metal body panels/hoods and full trunk floor and roof when compared to yours. I have to keep metal fenders for my vintage class.
J P Stein |
Jul 27 2013, 07:08 AM
High HP works only when you're OTG, whereas light weight works all the time..... Just something to file in the back if your mind. At some HP/Torque point, a weight increase becomes inevitable.
Brit has doubled his HP with an expense that an AC Porsche motor cost that would more than double..... while maintaining the low CG that is something I would not give up. There are few even semi-affordable options that maintain that low CG and none of them say Porsche on em'. |
Randal |
Jul 27 2013, 09:00 AM
High HP works only when you're OTG, whereas light weight works all the time..... Just something to file in the back if your mind. At some HP/Torque point, a weight increase becomes inevitable. Brit has doubled his HP with an expense that an AC Porsche motor cost that would more than double..... while maintaining the low CG that is something I would not give up. There are few even semi-affordable options that maintain that low CG and none of them say Porsche on em'. You are right, it's just hard to swallow. |
Jul 28 2013, 06:29 PM
Resident German Group: Admin Posts: 41,606 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I understand that people want to go faster, but what's the point of running a Porsche without a Porsche motor?
If you want to drive a subie so bad, use a damn subie for your racecar. I never got that ... (IMG:style_emoticons/default/confused24.gif) |
ConeDodger |
Jul 28 2013, 07:01 PM
Apex killer! Group: Members Posts: 23,561 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
I understand that people want to go faster, but what's the point of running a Porsche without a Porsche motor? If you want to drive a subie so bad, use a damn subie for your racecar. I never got that ... (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/agree.gif) |
Jul 28 2013, 07:38 PM
I understand that people want to go faster, but what's the point of running a Porsche without a Porsche motor? If you want to drive a subie so bad, use a damn subie for your racecar. I never got that ... (IMG:style_emoticons/default/confused24.gif) Twin turbo..... |
carr914 |
Jul 28 2013, 09:56 PM
Racer from Birth Group: Members Posts: 118,181 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
I'm hoping to see 220+ hp and 175 ftlbs but the torque may be a bit on the optimistic side. I intend to build it with a very light rotating mass and use a non counterweighted 2.0 crankshaft with E cams. I would like to have a 8,000 rpm redline and gear the car low. I think this could work if I keep the car light. Granted I am just now beginning to aquire the parts needed and have no idea how I am going to be able to afford everything. Buying a 3.2 or a 3.6 would be cheaper but I already have the 2.7. Numbers aren't far off. I got 214hp, 185ftlbs out of this 2.5 |
Randal |
Jul 28 2013, 10:07 PM
I'm hoping to see 220+ hp and 175 ftlbs but the torque may be a bit on the optimistic side. I intend to build it with a very light rotating mass and use a non counterweighted 2.0 crankshaft with E cams. I would like to have a 8,000 rpm redline and gear the car low. I think this could work if I keep the car light. Granted I am just now beginning to aquire the parts needed and have no idea how I am going to be able to afford everything. Buying a 3.2 or a 3.6 would be cheaper but I already have the 2.7. Numbers aren't far off. I got 214hp, 185ftlbs out of this 2.5 On the dyno or to the wheels? Beautiful motor! |
Lo-Fi Version | Time is now: 27th April 2024 - 01:05 AM |
