SCCA rules, rule out big bore motors |
Randal |
Jul 26 2013, 09:59 AM
Advanced Member Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
At least in XP.
A fantasy of mine is to keep my car all Porsche and put in a 993 3.6. While the car would be +/-100 pounds heaver it would have over 300hp (with Varioram) and around 250lbs of torque. It would be a great hill climb car able to compete with the big bore modified cars. OK, but then what do you do the rest of the year? XP rules would dictate ballasting up to 1997#. Are you kidding me? So the only way to be competitive in XP is to convert to a Suby or shove in a twin turbo motor, just like everyone else. Annoying. |
carr914 |
Jul 28 2013, 09:56 PM
Racer from Birth Group: Members Posts: 118,695 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
I'm hoping to see 220+ hp and 175 ftlbs but the torque may be a bit on the optimistic side. I intend to build it with a very light rotating mass and use a non counterweighted 2.0 crankshaft with E cams. I would like to have a 8,000 rpm redline and gear the car low. I think this could work if I keep the car light. Granted I am just now beginning to aquire the parts needed and have no idea how I am going to be able to afford everything. Buying a 3.2 or a 3.6 would be cheaper but I already have the 2.7. Numbers aren't far off. I got 214hp, 185ftlbs out of this 2.5 |
Randal |
Jul 28 2013, 10:07 PM
I'm hoping to see 220+ hp and 175 ftlbs but the torque may be a bit on the optimistic side. I intend to build it with a very light rotating mass and use a non counterweighted 2.0 crankshaft with E cams. I would like to have a 8,000 rpm redline and gear the car low. I think this could work if I keep the car light. Granted I am just now beginning to aquire the parts needed and have no idea how I am going to be able to afford everything. Buying a 3.2 or a 3.6 would be cheaper but I already have the 2.7. Numbers aren't far off. I got 214hp, 185ftlbs out of this 2.5 On the dyno or to the wheels? Beautiful motor! |
Lo-Fi Version | Time is now: 19th May 2024 - 01:39 PM |
