Fuel Pump Power Question |
lsintampa |
Aug 1 2013, 12:05 PM
Senior Member Group: Members Posts: 520 Joined: 28-January 13 From: Tampa, FL Member No.: 15,441 Region Association: South East States |
75 914/4 2.0 FI
I pulled out my fuel pump and hooked it up to 12V supply and it just doesn't spin like I'd expect. SO, I assume it's dead. In any event, I hook up a voltmeter to where the fuel pump connects and when I turn the ignition to the on position, all I get is about .50 volts. Shouldn't I be getting a reading near 12 volts? The wire I'm thinking is the fuel pump power is black / red - it's the only wire near where the fuel pump mounts, so I assume that at least is correct. Thanks, Len |
Lo-Fi Version | Time is now: 19th May 2024 - 02:31 AM |
