75 914/4 2.0 FI
I pulled out my fuel pump and hooked it up to 12V supply and it just doesn't spin like I'd expect.
SO, I assume it's dead.
In any event, I hook up a voltmeter to where the fuel pump connects and when I turn the ignition to the on position, all I get is about .50 volts.
Shouldn't I be getting a reading near 12 volts?
The wire I'm thinking is the fuel pump power is black / red - it's the only wire near where the fuel pump mounts, so I assume that at least is correct.
Thanks,
Len
