Parking break, warning light |
Elliot Cannon |
Aug 3 2013, 02:13 PM
Turned the switch to start the car and the parking brake warning light is flashing even with the brake off or with the switch pushed down with my finger. Is there anything else that would cause that light to flash besides the parking break or emergency flashers?
Elliot Cannon |
Aug 3 2013, 04:01 PM
Thanks. I had just bled my brakes and forgot all about that reset. I was able to reach in with a long steel rod and reset the switch. Yes, I did a pre-flight. I found a warning light blinking and called someone. (IMG:style_emoticons/default/laugh.gif)
Cheers, Elliot |
Eric_Shea |
Aug 3 2013, 04:03 PM
Break?
Elliot Cannon |
Aug 3 2013, 04:05 PM
Break? I bought them from you didn't I? (IMG:style_emoticons/default/happy11.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/lol-2.gif) |
aharder |
Aug 3 2013, 08:16 PM
Advanced Member Group: Members Posts: 4,402 Joined: 6-September 11 From: Dallas Texas Member No.: 13,524 Region Association: Southwest Region |
What is the process to reset? I have the same issue.
Aug 3 2013, 09:00 PM
Custom Member Group: Members Posts: 24,584 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Press button on the brass electrical switch mounted on the mater cylinder.
Access it via the drivers side wheel well with a good light and a long rod. Rich |
Elliot Cannon |
Aug 3 2013, 09:31 PM
Aug 3 2013, 11:01 PM
914 Idiot Group: Members Posts: 14,991 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
If you turn the wheel all the way to the right, you don't even need the long rod. Just reach in with your hand.
--DD |
Lo-Fi Version | Time is now: 29th May 2024 - 07:04 AM |
