Turned the switch to start the car and the parking brake warning light is flashing even with the brake off or with the switch pushed down with my finger. Is there anything else that would cause that light to flash besides the parking break or emergency flashers?
Elliot Cannon
Aug 3 2013, 04:01 PM
Thanks. I had just bled my brakes and forgot all about that reset. I was able to reach in with a long steel rod and reset the switch. Yes, I did a pre-flight. I found a warning light blinking and called someone. Cheers, Elliot
Eric_Shea
Aug 3 2013, 04:03 PM
Break?
Elliot Cannon
Aug 3 2013, 04:05 PM
QUOTE(Eric_Shea @ Aug 3 2013, 03:03 PM)
Break?
I bought them from you didn't I?
aharder
Aug 3 2013, 08:16 PM
What is the process to reset? I have the same issue.
r_towle
Aug 3 2013, 09:00 PM
Press button on the brass electrical switch mounted on the mater cylinder.
Access it via the drivers side wheel well with a good light and a long rod.
Rich
Elliot Cannon
Aug 3 2013, 09:31 PM
QUOTE(r_towle @ Aug 3 2013, 08:00 PM)
Rich
Exactly what I did. Took about 2 minutes.
Dave_Darling
Aug 3 2013, 11:01 PM
If you turn the wheel all the way to the right, you don't even need the long rod. Just reach in with your hand.
--DD
