Web-Cam, Need info on the gear and where to order |
Hammer920 |
Dec 7 2004, 08:29 AM
It's a Learning Experience Group: Members Posts: 83 Joined: 27-April 04 From: Levelland, TX Member No.: 1,989 |
I am checking on prices to get we-cam shaft and gear, my question is I have a -3 gear all I have found is -0- , if I go this route does the crank shaft timeing gear have to be replaced also. going back stock for FI will also order the web cam lifters. need good resorce to purchase these Pelican out of stock on -3 gears or does this matter. Everyting now cleanned up on the block crankshaft miked and polished is in good shape. Now the process of putting back togeather as per Jakes video. (IMG:style_emoticons/default/biggrin.gif)
Hammer PS: working late shift will ck early mornings. |
Jake Raby |
Dec 7 2004, 09:18 AM
The +/- days are pretty much gone... meaning that since many gears have worn a tad anyway and the cams are no longer " factory" that the days of matching things up totally are history.
For 90% of cases the _0_ gear works fine, and gives proper msh and backlash. |
Demick |
Dec 7 2004, 09:28 AM
Call webcam. I believe that although they list the gear as a -0-, it is really a -3, and they will tell you that on the phone. It is the only size they make anymore.
Demick |
Hammer920 |
Dec 7 2004, 09:12 PM
Thanks for all the information, that really helps (IMG:style_emoticons/default/biggrin.gif)
newdeal2 |
Dec 7 2004, 09:53 PM
Unregistered |
I got my cam from Jake and the gear from Webcam [ -3], Jake modified it for the Type 1 oil pump. Works great.
Hammer920 |
Dec 8 2004, 08:54 AM
gonna call web cam Friday or either call air cooled for both.... the oil baffels that are or were in it jake stated was not needed in an earlier posting, what do I need to get to modify that? HEhehe..... (IMG:style_emoticons/default/smile.gif) I have got a real good christmas list....
Lo-Fi Version | Time is now: 16th May 2024 - 06:22 AM |
