911 transmission kaboom |
Dr Evil |
Aug 5 2013, 07:31 PM
Send me your transmission! Group: Members Posts: 23,000 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Cupomeat is the talent behind my rebuild DVD not sucking and actually being entertaining AND informative. He did all of the work other than what I did in front of the camera. Wouldnt it be, that the transmission that I rebuilt for his Dad's early 911 would be the first that I have ever seen break a pinion after rebuild. Of course, it was a more rare and expensive 8 toothed pinion as well (IMG:style_emoticons/default/dry.gif)
I was a bit confused on how this happened, but it was the obvious failure and matched Meat's description of events. Tonight I was able to get more personal with the gear stack and soon realized that there was more to this catastrophe. I first noticed that the carrier for 1/R slider was badly galled and chewed up on a face that should not have any wear: Then I looked at what it rested against, the 1st gear race and bearing. Holy shit. The bearing fused and locked up first. Oddly enough, 1st did not break and the pinion did. This may be because the pinion is weaker having more teeth than our 7 toothed variety. Strange stuff. No idea why this happened. I had to beat the gear off of the race, which looked like this: I still have not been able to get the pinion out. I will have to cut the race as it is all kinds of messed up as was the end of the pinion. What a crazy failure. I am glad that this was the only I have seen in a rebuild in 10 years. I have found others in cores, but these were neglected cores. Gonna need some parts (IMG:style_emoticons/default/smile.gif) |
Dr Evil |
Aug 5 2013, 08:13 PM
1- not my fault.
2- I was sober. (IMG:style_emoticons/default/bootyshake.gif) |
Dr Evil |
1- not my fault.
scotty b |
Aug 5 2013, 09:33 PM
Hack (IMG:style_emoticons/default/dry.gif) I'm getting Erc the 3rd (Wills) to rebuild my trannies from now on (IMG:style_emoticons/default/mad.gif)
Aug 5 2013, 09:51 PM
You can say that again... I think next time, you should start drinking before you start building, then. --DD |
oldschool |
Aug 5 2013, 11:15 PM
Advanced Member Group: Members Posts: 3,362 Joined: 29-October 08 From: P-town Member No.: 9,705 Region Association: Southern California |
(IMG:style_emoticons/default/drunk.gif) (IMG:style_emoticons/default/av-943.gif) ....I have a cool DVD you can have. (IMG:style_emoticons/default/slap.gif)
bulitt |
Aug 6 2013, 04:35 AM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
One failure in a decade and y'all throw the Doc under the bus? Whats wrong with you guys?
Um, Doc...you don't perform surgery do you??? (IMG:style_emoticons/default/biggrin.gif) |
Dr Evil |
Aug 6 2013, 07:22 AM
I cut people, for work (IMG:style_emoticons/default/smile.gif) Is good fun.
Chris H. |
Aug 6 2013, 08:50 AM
Senior Member Group: Members Posts: 4,030 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Looks like classic Fetzer Valve failure. Nothing you can do about that.
Dr Evil |
Aug 6 2013, 08:57 AM
The springly sprocket encabulated. I just need to realign the eddy current transfuser and it will be fine.
0396 |
Aug 6 2013, 09:52 AM
Advanced Member Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
Can the above mishap be caused by incorrect tolerance during rebuild and or wrong gear oil?
Dr Evil |
Aug 6 2013, 09:59 AM
Yes, but these were not factors encountered with this rebuild and run.
Woody |
Sandbox Rabblerouser and head toilet scrubber Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region |
Doc is slipping in his old age. (IMG:style_emoticons/default/hitfan[1].gif)
bulitt |
Aug 6 2013, 10:04 AM
Yes, but he is now proficient at split rail fence building (IMG:style_emoticons/default/smash.gif) and diaper changing! (IMG:style_emoticons/default/hissyfit.gif)
Dr Evil |
Aug 6 2013, 10:17 AM
Fences, no. Diapers..... I can change a diaper like the guys change tires in the pit. air tools!
Woody |
Aug 6 2013, 12:27 PM
Fences, no. Diapers..... I can change a diaper like the guys change tires in the pit. air tools! sounds messy. (IMG:style_emoticons/default/stromberg.gif) |
Aug 6 2013, 12:47 PM
Custom Member Group: Members Posts: 24,577 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Yes, but have you been pissed on yet while changing.....rights of passage
Dr Evil |
Aug 6 2013, 02:15 PM
Aug 6 2013, 08:24 PM
Face or did you catch it in time?
Cupomeat |
Aug 7 2013, 07:55 AM
missing my NY 914 in VA Group: Members Posts: 1,336 Joined: 26-November 07 From: Oakton VA Member No.: 8,376 Region Association: MidAtlantic Region |
Lo-Fi Version | Time is now: 20th May 2024 - 10:21 PM |
