New Optima 34R Red Top battery doesn't fit. Suggestions? |
tumamilhem |
Aug 8 2013, 05:59 PM
LUFTBRIGADE Group: Members Posts: 1,228 Joined: 29-October 12 From: Jacksonville, FL Member No.: 15,092 Region Association: South East States |
So to much suggestion, I purchased the Optima 34R (size for 914s) Red Top battery. Only it doesn't fit in the tray. Two tabs petruding on both sides extend past the raised edge of the battery tray, not allowing it to sit in place. I know many use this battery. Suggestions on how to remedy? Or get a different size?
JeffBowlsby |
Aug 8 2013, 06:03 PM
914 Wiring Harnesses Group: Members Posts: 8,507 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
They are just tabs, trim them off with a utility knife.
RFoulds |
Aug 8 2013, 06:19 PM
Green Teen 66 Group: Members Posts: 837 Joined: 10-August 09 From: La Quinta, CA Member No.: 10,656 Region Association: Southwest Region |
it should fit as is though. maybe a nonstock battery tray? mine always fit easily.
ednosnaws |
Aug 8 2013, 06:21 PM
Newbie Group: Members Posts: 17 Joined: 20-November 12 From: San Diego, CA Member No.: 15,171 Region Association: Southern California |
So to much suggestion, I purchased the Optima 34R (size for 914s) Red Top battery. Only it doesn't fit in the tray. Two tabs petruding on both sides extend past the raised edge of the battery tray, not allowing it to sit in place. I know many use this battery. Suggestions on how to remedy? Or get a different size? I turned over the battery and cut one tab off with a jigsaw using a metal blade. |
Harpo |
Aug 8 2013, 06:36 PM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
Mine fit fine however I had to make my own bracket to hold the battery down.
DAvid |
chad newton |
Aug 8 2013, 07:17 PM
Member Group: Members Posts: 110 Joined: 26-August 11 From: behind the red curtain Member No.: 13,491 Region Association: None |
Move it to the front:)
sportlicherFahrer |
Aug 8 2013, 07:25 PM
Nothing to see here. Group: Members Posts: 1,079 Joined: 18-April 05 From: Tacoma, WA Member No.: 3,945 Region Association: Pacific Northwest |
Trim the tabs a little bit. If you want to secure it correctly, Triad West Performance makes an aluminum plate specifically for the optimas for $26 with hardware. Mine is locked down pretty solid.
TheCabinetmaker |
Aug 8 2013, 07:38 PM
Optima will send you one for free.
Aug 8 2013, 07:59 PM
Optima will send you one for free. (IMG:style_emoticons/default/agree.gif) They have a bracket that fits the 914 to hold them down securely. Got mine for free ... (IMG:style_emoticons/default/piratenanner.gif) |
Aug 8 2013, 08:13 PM
Does cutting the tabs void the warrantee?
tumamilhem |
Aug 8 2013, 08:47 PM
tumamilhem |
Aug 8 2013, 08:49 PM
Optima will send you one for free. (IMG:style_emoticons/default/agree.gif) They have a bracket that fits the 914 to hold them down securely. Got mine for free ... (IMG:style_emoticons/default/piratenanner.gif) How/where did you guys get your brackets and battery trays? Do I just email Optima though their website and request the bracket and tray? |
tumamilhem |
Aug 8 2013, 09:23 PM
Now I can't close the damn engine lid. It doesn't clear the rain tray. And I'm not cutting my rain tray. Anybody else have this problem? I do have the right one, right? 34R?
SLITS |
Aug 9 2013, 06:51 AM
Can't tell you. One car I put it in the front trunk and the other car I put it in the rear trunk. (IMG:style_emoticons/default/biggrin.gif)
rhodyguy |
Aug 9 2013, 11:07 AM
the optima (johnson controls) hold down they used to send you is called a "Group 78 Adapter". last time i called to inquire about one the person on the other end had no idea what i was talking about.
k |
tumamilhem |
Aug 9 2013, 07:33 PM
I cut the tabs off and it fits in the tray now. But the positive terminal still prevents the engine lid from closing all the way. :/
computers4kids |
Aug 10 2013, 10:18 AM
Love these little cars! Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
David J |
Aug 10 2013, 10:13 PM
Newbie Group: Members Posts: 29 Joined: 18-June 12 From: Dallas Member No.: 14,577 Region Association: Southwest Region |
I've seen these batteries rotated on their side, with the terminals pointing out instead of up. Would that be an option for your situation?
tumamilhem |
Aug 11 2013, 07:57 AM
I've seen these batteries rotated on their side, with the terminals pointing out instead of up. Would that be an option for your situation? Would that effect the battery performance at all? I don't know how I would secure it either. I think the battery tra y was re-welded too high. I thought even though these batteries are high, there's still plenty of clearance. I'm going to measure the distance in height in this car and my other one. In the meantime, I can shut my lid but it's pushing up that side of the engine lid which could eventually bend the metal. And it's obviously petruding above the rear deck. Damn it. |
McMark |
Aug 11 2013, 09:29 AM
I realize you bought the 34R to keep the POS/NEG terminals oriented correctly, but can you rotate the battery and keep the terminals towards the wall? Make sure to get plastic/rubber insulators for your POS terminal.
Lo-Fi Version | Time is now: 17th May 2024 - 07:54 AM |
