| KELTY360 |
Aug 11 2013, 07:38 AM
914 Neferati ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,192 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest
I've had the car 7 years and usually have to adjust the cable about every 6 months to restore complete engagement and smooth shifting, most notably in first or reverse. Now, I can adjust as usual and it works fine, but only for a few miles when it won't fully disengage and becomes very difficult to get into first or reverse without grinding.
A new cable was installed 3 years ago and has worked fine til now. Is it just stretching out and needs replacement or could there be something more sinister going on? |
| Millerwelds |
Aug 11 2013, 07:42 AM
Pleepleus ![]() ![]() ![]() Group: Members Posts: 741 Joined: 24-June 08 From: Grass Valley, CA Member No.: 9,206 Region Association: Northern California |
Do you have it secured with two nuts locked together so the adjustment is not changing?
| KELTY360 |
Aug 11 2013, 07:49 AM
| JoeSharp |
Aug 11 2013, 07:54 AM
In Irvine, Ca. May 15-18 ![]() ![]() ![]() ![]() Group: Members Posts: 3,947 Joined: 9-July 03 From: DeLand, Florida Member No.: 898 Region Association: South East States |
It's gone. Replace it before it leves you stranded and shows you where the strands are.
| 76-914 |
Aug 11 2013, 08:12 AM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,966 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
(IMG:style_emoticons/default/agree.gif) That or a spot weld on the clutch tube has failed.
| Spoke |
Aug 11 2013, 08:16 AM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,429 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
I had the same problem on both of my 914s.
The first one kept needing adjustment until I noticed the clutch tube moving toward the interior of the car. The tube attachment at the firewall had rusted. On the other 914, a few adjustments days apart preceded a big BANG when the clutch pedal when to the floor as the cable broke. If the clutch tube is not rusted at the firewall, replace the cable before you drive it further. |
| KELTY360 |
Aug 11 2013, 08:27 AM
I haven't checked the tube. I'll do that.
| KELTY360 |
Aug 12 2013, 11:48 PM
The tube checked out fine. Turns out the cable was frayed on the outer winding while the inner core was intact. Smooth clutch operation restored! (IMG:style_emoticons/default/cheer.gif)
Thanks to Greenie for helping out. In spite of what people say, he's not a bad guy.....don't tell him I said that. (IMG:style_emoticons/default/grouphug.gif) |
| tracks914 |
Aug 13 2013, 10:24 AM
Canadian Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,083 Joined: 15-January 03 From: Timmins, Ontario, Canada Member No.: 153 Region Association: None |
Lo-Fi Version | Time is now: 22nd September 2026 - 06:38 AM |
