Bolt-in solution for maintaining door gaps? |
stateofidleness |
Aug 11 2013, 05:57 PM
Senior Member Group: Members Posts: 810 Joined: 1-September 07 From: Canyon Lake, Texas! Member No.: 8,065 Region Association: None |
Gents,
I need to cut out the rear part of the floor on both sides and I'm not really sure if I need to do anything to maintain the door gaps or not. I didn't really want to have to weld anything to the door frame as I want to keep the original paint and all that. I was wondering if 1) does cutting out the rear part of the floor require any bracing and 2) if it does, is there a "bolt in" type solution that could be used instead of having to weld bars? |
Porsche930dude |
Aug 11 2013, 06:20 PM
Member Group: Members Posts: 399 Joined: 25-November 11 From: Vestal NY Member No.: 13,819 Region Association: None |
i would say as long as you dont get into the longs you should be ok. but you can put jackstands to suport the front and back independently so its not moving anywhere. 3 in front and 3 in back. and make sure everything is level before you cut
jimkelly |
Aug 11 2013, 06:30 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
I've seen some that bolt to the 2 door hinges and V to one bolt point at top seat belt point.
this pic is close. (IMG:http://www.914world.com/bbs2/uploads_offsite/www.tangerineracing.com-2460-1376267447.1.jpg) |
stateofidleness |
Aug 11 2013, 06:37 PM
I've got the car up on 4 ramps at the moment and the longs are actually very solid, just the floors have enough swiss cheese for me to want to swap them out completely (this is easier right??).
jimkelly |
Aug 11 2013, 06:49 PM
seems like you'll be fine.
see some good pics here about floor pan replacement. http://www.914world.com/bbs2/index.php?sho...=78501&st=0 |
Lo-Fi Version | Time is now: 21st May 2024 - 08:46 PM |
