| tomeric914 |
Aug 11 2013, 09:30 PM
One Lap of America in a 914! ![]() ![]() ![]() Group: Members Posts: 1,325 Joined: 25-May 08 From: Syracuse, NY Member No.: 9,101 Region Association: North East States
I searched but could not find. Looking for the sail panel bottom trim hole dimensional locations. This is for the 4 holes on the bottom of the sail that hold the thin chrome trim.
They aren't on the body dimension page and aren't in any of the sail vinyl instructions either. |
| pilothyer |
Aug 11 2013, 09:37 PM
Member ![]() ![]() ![]() Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
Maybe you can look on the inside and see where the bondo squished into the holes when they were filled in, then just go from there.
| iamchappy |
Aug 11 2013, 10:02 PM
It all happens so fast! ![]() ![]() ![]() ![]() Group: Members Posts: 4,893 Joined: 5-November 03 From: minnetonka, mn Member No.: 1,315 Region Association: Upper MidWest |
What i did was i had some old sail trim that i drilled four holes spaced out in the approximate location of the holes shown in the sail panel vinyl replacement thread. Place them on the lower sail panel, marked and drilled the holes.
http://www.914world.com/bbs2/index.php?showtopic=14625 |
| tomeric914 |
Aug 12 2013, 08:01 AM
Maybe you can look on the inside and see where the bondo squished into the holes when they were filled in, then just go from there. Except that this is a replacement NOS fender that has no holes. When I removed the damaged fender, I nibbled right across the holes. (IMG:style_emoticons/default/slap.gif) What i did was i had some old sail trim that i drilled four holes spaced out in the approximate location of the holes shown in the sail panel vinyl replacement thread. Place them on the lower sail panel, marked and drilled the holes. http://www.914world.com/bbs2/index.php?showtopic=14625 Ya know, I looked at that thread a couple of times and didn't see the holes shown. Looking again, I can get the relative locations from that thread. Thanks. As much as I don't want to, I may take the trim off the other side and measure. I just don't want to chance messing up the trim if I don't have to. |
Lo-Fi Version | Time is now: 20th November 2026 - 11:29 AM |
