1973 steering colum switch removal-RESOLVED, Installing a Momo horn button |
HalfMoon |
Aug 12 2013, 05:06 PM
Senior Member Group: Members Posts: 828 Joined: 13-November 12 From: Shenandoah Junction, WV Member No.: 15,144 Region Association: MidAtlantic Region |
Hi all!
Just one last thing to sort out and I can get my recently purchased darkside teener inspected! I need to install on the Momo steering wheel the PO supplied Momo horn button and hook up the horns I sourced from a 928 I had laying around. I think I've found the black/yellow or is it black/orange wire in the front harness, but when I looked for a wire in the steering colum I didn't find one. I removed the steering wheel and figured I'd reverse engineer to try and find the green/white striped wire that needs to be attatched to the horn button. I removed the 4 retaining screws for the switches but the switches would not come out all the way :-( Haynes doesn't describe the exact procedure. Does anyone know the trick for removing the steering colum switches from a 1973? Keep in mind 73 had some changes and what may work for a 72 or 74 could very possibly NOT work on my 73. And, of course if anyone happens to have the install instructions from Momo that would be of great help (although I sent them a email request just today). Thanks everyone! We've gotten alot done sorting this car for inspection in WV :-) Pix attatched. |
Aug 12 2013, 05:14 PM
Look at the hub from the stock wheel.
The ground wire should be on there. |
Mike Bellis |
Aug 12 2013, 05:27 PM
The horn wire is brown/white NOT green/white. You cannot see it from there anyway. The big C shaped contact it for the horn. It touches the hub that has a wire that connects to the button you have.
Put the steering column back together. No need to take it apart. |
bulitt |
Aug 12 2013, 05:35 PM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
Yes, black/yellow from the horn to the relay. Look for a Brown/White from the relay to the steering column. The concept is when the horn button is depressed the brown/white wire goes to ground blowing the horn. As Mike says, you cant see it.
The OEM contact ring (has a wire on it) screws onto the back side of the MOMO adapter with three self tapping screws included with the hub, then pass the wire thru the hole, and it hooks up to the horn button Included with the horn button should be a snap ring which is an "expansion ring" that puts tension on the 'fingers' of the horn button to stay put inside the hub. On the horn button- one spade connector should be labeled ground, and one is for the button itself. The ground spade should connect to the adapter. The other spade connects to the contact ring with a wire. |
Valy |
Aug 12 2013, 06:10 PM
Senior Member Group: Members Posts: 1,675 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
The switch is probably hold in there by the windshield washer rubber hoses. If you pull hard, it will come off but you'll need to remove the column covers to reassemble.
Anyway, you don't need to remove it. The horn button makes contact by grounding the C shaped stripes around the switch. You should use the canceling ring and horn contact that's on the original steering wheel. Take it off and mount it on the Momo wheel. regarding the wires, you'll find 2 sets of wires behind the front bumper grill: one for the horn and the other for the fog lights. The wires are all there even if you don't have the lights. The horn wire goes through a relay between the button and the horn. The horn wires in the bumper are black/yellow (+) and brown (-). The foglight wires are white/yellow (+) and brown (-). Hope it helps. |
HalfMoon |
Aug 12 2013, 06:15 PM
HalfMoon |
Aug 12 2013, 06:16 PM
The horn wire is brown/white NOT green/white. You cannot see it from there anyway. The big C shaped contact it for the horn. It touches the hub that has a wire that connects to the button you have. Put the steering column back together. No need to take it apart. I broke a contact on the wiper switch so I will need to take it apart and repair that. How do you remove it though? |
HalfMoon |
Aug 12 2013, 06:18 PM
Yes, black/yellow from the horn to the relay. Look for a Brown/White from the relay to the steering column. The concept is when the horn button is depressed the brown/white wire goes to ground blowing the horn. As Mike says, you cant see it. The OEM contact ring (has a wire on it) screws onto the back side of the MOMO adapter with three self tapping screws included with the hub, then pass the wire thru the hole, and it hooks up to the horn button Included with the horn button should be a snap ring which is an "expansion ring" that puts tension on the 'fingers' of the horn button to stay put inside the hub. On the horn button- one spade connector should be labeled ground, and one is for the button itself. The ground spade should connect to the adapter. The other spade connects to the contact ring with a wire. Nothing like that was included. What you see is what I have to work with. |
HalfMoon |
Aug 12 2013, 06:37 PM
Yes, black/yellow from the horn to the relay. Look for a Brown/White from the relay to the steering column. The concept is when the horn button is depressed the brown/white wire goes to ground blowing the horn. As Mike says, you cant see it. The OEM contact ring (has a wire on it) screws onto the back side of the MOMO adapter with three self tapping screws included with the hub, then pass the wire thru the hole, and it hooks up to the horn button Included with the horn button should be a snap ring which is an "expansion ring" that puts tension on the 'fingers' of the horn button to stay put inside the hub. On the horn button- one spade connector should be labeled ground, and one is for the button itself. The ground spade should connect to the adapter. The other spade connects to the contact ring with a wire. I gather that I'm missing some components of the Momo installation kit? The adaptor ring which you spoke of that would mount on the bottom of the Momo hub? See pix |
bulitt |
Aug 12 2013, 06:44 PM
Do you have this OEM contact ring?
(IMG:http://www.914world.com/bbs2/uploads_offsite/c767170.r70.cf2.rackcdn.com-13632-1376354674.1.jpg) Number four in the exploded parts view- click this link Steering diagram |
bulitt |
Aug 12 2013, 06:51 PM
looks like the tension circlips are not for every wheel. Newer buttons just pop in
Look down about 4 pics and there is a round ring which fits between the hub and the wheel. This is the MOMO ground ring. This is where the ground wire from the horn button spade goes. (there is a spade on this ring) however you can attach the horn button ground anywhere on the hub. So, you should have the following. 1) OEM contact ring fastened to bottom of MOMO hub with wire going up through hub to horn button. 2) Hub 3) MOMO ground ring 4) Wheel 5) possibly a round cinching ring that all the bolts go through (can see you dont need it with your wheel) 6) Horn button (IMG:http://www.914world.com/bbs2/uploads_offsite/lib.store.yahoo.net-13632-1376355098.1.jpg) |
HalfMoon |
Aug 12 2013, 07:10 PM
Do you have this OEM contact ring? (IMG:http://www.914world.com/bbs2/uploads_offsite/c767170.r70.cf2.rackcdn.com-13632-1376354674.1.jpg) Number three in the explode parts view- click this link Steering diagram Dang! Nope I don't have this part. PO had mounted the Momo steering wheel but this wasn't part of his installation. |
bulitt |
Aug 12 2013, 07:14 PM
place an ad in the classifieds-someone must have one, or 29$ at Auto atlanta
HalfMoon |
Aug 12 2013, 07:16 PM
looks like the tension circlips are not for every wheel. Newer buttons just pop in Look down about 4 pics and there is a round ring which fits between the hub and the wheel. This is the MOMO ground ring. This is where the ground wire from the horn button spade goes. (there is a spade on this ring) however you can attach the horn button ground anywhere on the hub. So, you should have the following. 1) OEM contact ring fastened to bottom of MOMO hub with wire going up through hub to horn button. 2) Hub 3) MOMO ground ring 4) Wheel 5) possibly a round cinching ring that all the bolts go through (can see you dont need it with your wheel) 6) Horn button (IMG:http://www.914world.com/bbs2/uploads_offsite/lib.store.yahoo.net-13632-1376355098.1.jpg) Extremely valuable intel! Thanks! |
Mike Bellis |
Aug 12 2013, 07:25 PM
A 924 ring will also fit if you can't find a 914. It mounts with the 3 tiny screw holes on the bottom of your hub.
The guts for the column should pull right out. It will be snug as there is a connector below that is a tight fit. Pull it straight up and out. |
HalfMoon |
Aug 12 2013, 07:34 PM
Do you have this OEM contact ring? (IMG:http://www.914world.com/bbs2/uploads_offsite/c767170.r70.cf2.rackcdn.com-13632-1376354674.1.jpg) Number three in the explode parts view- click this link Steering diagram Dang! Nope I don't have this part. PO had mounted the Momo steering wheel but this wasn't part of his installation. COOL! I looked through some parts the PO sent along with the car and found THIS! Didn't find the Momo adaptor ring though :-( |
bulitt |
Aug 12 2013, 07:43 PM
Really dont need the MOMO ground ring. Just drill and tap a small hole in some unobtrusive place in the inside bottom of the hub to connect the button ground wire ?
HalfMoon |
Aug 12 2013, 07:51 PM
HalfMoon |
Aug 12 2013, 07:53 PM
A 924 ring will also fit if you can't find a 914. It mounts with the 3 tiny screw holes on the bottom of your hub. The guts for the column should pull right out. It will be snug as there is a connector below that is a tight fit. Pull it straight up and out. Crap. Had I not broken a connection on the wiper switch I'd not have to remove the entire switch to facilitate a repair :-( Grrrr. Mebbe I can get a soildering iron on it without totally removing the bugger? In the morning...tarred (but not feathered). Must eat and sleep. |
HalfMoon |
Aug 12 2013, 07:57 PM
Really dont need the MOMO ground ring. Just drill and tap a small hole in some unobtrusive place in the inside bottom of the hub to connect the button ground wire ? Actually I was thinking I could just use a flat eye connector with a line on it and attatch it to one of the OEM hub mounting holes. That'll ground it. Run the wire up through the hole and connect to the ground on the button. |
Lo-Fi Version | Time is now: 17th May 2024 - 07:56 AM |
