lsintampa |
Senior Member ![]() ![]() ![]() Group: Members Posts: 520 Joined: 28-January 13 From: Tampa, FL Member No.: 15,441 Region Association: South East States ![]() |
75 914/4 2.0 FI
OK, so while I'm waiting on the final verdict on my fuel injector cleaning project, I thought I'd chase down an oil leak. What I found was that oil was seeping out of the cover plate for the remote oil temp sender. I removed the cover plate that is held on by two 10mm bolts. With the cover removed, oil really seeped out of the bolt holes. I assume and hope that's OK? Question is, if they leak that bad, shouldn't there be a gasket for that cover? The cover and the plate that the sender mounts to were very nicely cleaned and powder coated, but no gasket. I see a gasket in the PET, but not sure if it is for the cover plate or the inside plate that the temp sender screws into? Thanks, Len |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
gasket
plate with sender gasket o-ring cover plate Both bolts have copper crush washers (one use only) as well. All of this is in a standard gasket kit, or you can get them all from one of the many vendors that we all buy from. rich |
type47 |
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region ![]() |
I removed the cover plate that is held on by two 10mm bolts. With the cover removed, oil really seeped out of the bolt holes. Yea, because those 2 bolts are the only thing that holds the cover plate, and base, on the case. If you had wiggled the base a little more, the base may have dropped out and you'd have gotten the whole oil sump dumped on the floor. I don't see how the gasket between the cover and the base does much. The red o ring and the sealing copper washers on the bolts do more... I see the assembly as: case red o ring (PET 111-05 #50 021.101.269 A) base with sender gasket (039.101.287 not shown in PET) cover held on by sealing copper washers (PET 111-05 #51 N013.803.2) and bolts, 6mm. http://www.914world.com/bbs2/index.php?showtopic=111454 http://www.914world.com/bbs2/index.php?act...=0#entry1242301 |
stugray |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None ![]() |
QUOTE If you had wiggled the base a little more, the base may have dropped out and you'd have gotten the whole oil sump dumped on the floor (IMG:style_emoticons/default/agree.gif) You can put it on without the outer cover, but the bolts have to be installed with the crush washer as if the cover was on. Chances are: trying to remove just the cover with a full sump will not end well. Stu |
lsintampa |
I removed the cover plate that is held on by two 10mm bolts. With the cover removed, oil really seeped out of the bolt holes. Yea, because those 2 bolts are the only thing that holds the cover plate, and base, on the case. If you had wiggled the base a little more, the base may have dropped out and you'd have gotten the whole oil sump dumped on the floor. I don't see how the gasket between the cover and the base does much. The red o ring and the sealing copper washers on the bolts do more... I see the assembly as: case red o ring (PET 111-05 #50 021.101.269 A) base with sender gasket (039.101.287 not shown in PET) cover held on by sealing copper washers (PET 111-05 #51 N013.803.2) and bolts. http://www.914world.com/bbs2/index.php?showtopic=111454 http://www.914world.com/bbs2/index.php?act...=0#entry1242301 Wow - thanks. For once luck was on my side. Good to know. I pulled that cover off because I saw it was the source of my leak... once off, I left it off for a bit, but lucky for me, I put the bolts back in to stop the oil from dripping. For now, I made a paper gasket and slapped the cover back on. So when I go to do it right, how much oil can I expect to come out of there when I pull the whole thing out? |
ThePaintedMan |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,887 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States ![]() ![]() |
So when I go to do it right, how much oil can I expect to come out of there when I pull the whole thing out? ALL of it. Drain it first, and replace the seal with the appropriate parts. Probably better to do it before you start the engine for the first time, otherwise you're going to have to wait till you're ready to drain the oil. (IMG:style_emoticons/default/beerchug.gif) |
Valy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California ![]() |
See my signature for the paper gaskets.
0396 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California ![]() |
Valy, you da man. Thanks
Lo-Fi Version | Time is now: 30th July 2025 - 02:23 PM |
