Custom Gauge Lighting, DIY kits or send them to me |
timothy_nd28 |
Aug 15 2013, 11:24 PM
Advanced Member Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest |
I'm offering a service to retrofit the backlighting on your gauge cluster.
Full service is also available for $300.00. I will do all the labor with installing these LED's, paint the needles and do other cosmetic work which also includes replacing the plastic lenses with glass (if needed). For an extra 100 dollars, I will convert your tachometer to a modern air core servo tach that will work with any 4,6 or 8 cylinder engines. Some sample backlight colors you can choose with a simple push of a button on the remote control. Below is a video showing some extra features that the controller can do. https://www.youtube.com/watch?v=Byh23MwiMLY All the gauges illuminate red when the gas gauge gets too low. There is also a tachometer sensing circuit in the controller, that will change the background color at different RPM's (you tell me what RPM's, I then calibrate the controller to your settings) |
rnellums |
Sep 17 2015, 07:14 AM
Professional Enthusiast Group: Members Posts: 1,646 Joined: 26-November 09 From: Littleton, CO Member No.: 11,072 Region Association: Rocky Mountains |
I can't believe I hadn't posted about my experience here yet!
Tim worked closely with me to develop a gauge set that would work with my Subaru conversion. Not only was I able to keep the clean stock look of the dash, but it ended up being significantly less expensive than buying new aftermarket gauges! Now I also have very brightly lit gauges that transition to from white to bright red as I pass into the powder band. It makes driving at night even more enjoyable! |
mepstein |
May 23 2016, 06:10 PM
914-6 GT in waiting Group: Members Posts: 19,272 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I can't believe I hadn't posted about my experience here yet! Tim worked closely with me to develop a gauge set that would work with my Subaru conversion. Not only was I able to keep the clean stock look of the dash, but it ended up being significantly less expensive than buying new aftermarket gauges! Now I also have very brightly lit gauges that transition to from white to bright red as I pass into the powder band. It makes driving at night even more enjoyable! Well I guess I will have to hit Tim up when it's time to do my suby gauges. |
Tjmrfe |
Jul 25 2016, 03:59 PM
NON IMPEDING RATIONE COGITATIONIS Group: Members Posts: 132 Joined: 10-April 15 From: Cornwall on Hudson, New York Member No.: 18,612 Region Association: North East States |
I can't believe I hadn't posted about my experience here yet! Tim worked closely with me to develop a gauge set that would work with my Subaru conversion. Not only was I able to keep the clean stock look of the dash, but it ended up being significantly less expensive than buying new aftermarket gauges! Now I also have very brightly lit gauges that transition to from white to bright red as I pass into the powder band. It makes driving at night even more enjoyable! Well I guess I will have to hit Tim up when it's time to do my suby gauges. Hi, was wondering....do you sell replacement glass? I need one of the 60mm for my volt meter. Thanks...Terry. |
Lo-Fi Version | Time is now: 18th May 2024 - 04:24 AM |
