Custom Gauge Lighting, DIY kits or send them to me |
timothy_nd28 |
Aug 15 2013, 11:24 PM
I'm offering a service to retrofit the backlighting on your gauge cluster.
Full service is also available for $300.00. I will do all the labor with installing these LED's, paint the needles and do other cosmetic work which also includes replacing the plastic lenses with glass (if needed). For an extra 100 dollars, I will convert your tachometer to a modern air core servo tach that will work with any 4,6 or 8 cylinder engines. Some sample backlight colors you can choose with a simple push of a button on the remote control. Below is a video showing some extra features that the controller can do. https://www.youtube.com/watch?v=Byh23MwiMLY All the gauges illuminate red when the gas gauge gets too low. There is also a tachometer sensing circuit in the controller, that will change the background color at different RPM's (you tell me what RPM's, I then calibrate the controller to your settings) |
Mblizzard |
Sep 7 2013, 07:33 PM
Got them and they rock! Would highly recommend this to all. Besides the cool factor, it is a real safety improvement. The ability to actually be able to see your gauges is a real and tangible upgrade even if you set it to display factory color.
When I installed mine, I thought I had made a mistake in the fuel gauge wiring. But I thought I had more gas than in the tank. Well on a drive going around a curve, all the dash lights change to red! Yep it was working fine and it kept me from driving because I knew I had more gas. Sweet. Very sweet. |
Lo-Fi Version | Time is now: 4th May 2024 - 11:35 AM |
