Custom Gauge Lighting, DIY kits or send them to me |
timothy_nd28 |
Aug 15 2013, 11:24 PM
I'm offering a service to retrofit the backlighting on your gauge cluster.
Full service is also available for $300.00. I will do all the labor with installing these LED's, paint the needles and do other cosmetic work which also includes replacing the plastic lenses with glass (if needed). For an extra 100 dollars, I will convert your tachometer to a modern air core servo tach that will work with any 4,6 or 8 cylinder engines. Some sample backlight colors you can choose with a simple push of a button on the remote control. Below is a video showing some extra features that the controller can do. https://www.youtube.com/watch?v=Byh23MwiMLY All the gauges illuminate red when the gas gauge gets too low. There is also a tachometer sensing circuit in the controller, that will change the background color at different RPM's (you tell me what RPM's, I then calibrate the controller to your settings) |
beam944 |
Apr 25 2014, 06:50 PM
Member Group: Members Posts: 58 Joined: 15-April 14 From: Timberlake,NC Member No.: 17,254 Region Association: MidAtlantic Region |
Is there anyway to change the RPM range on the face to 10,000 ? I am doing a sbc 283 build with a red line of around 9-9500 and would love to keep the stock gauges.
Lo-Fi Version | Time is now: 4th May 2024 - 02:07 AM |
