Custom Gauge Lighting, DIY kits or send them to me |
timothy_nd28 |
Aug 15 2013, 11:24 PM
Advanced Member Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest |
I'm offering a service to retrofit the backlighting on your gauge cluster.
Full service is also available for $300.00. I will do all the labor with installing these LED's, paint the needles and do other cosmetic work which also includes replacing the plastic lenses with glass (if needed). For an extra 100 dollars, I will convert your tachometer to a modern air core servo tach that will work with any 4,6 or 8 cylinder engines. Some sample backlight colors you can choose with a simple push of a button on the remote control. Below is a video showing some extra features that the controller can do. https://www.youtube.com/watch?v=Byh23MwiMLY All the gauges illuminate red when the gas gauge gets too low. There is also a tachometer sensing circuit in the controller, that will change the background color at different RPM's (you tell me what RPM's, I then calibrate the controller to your settings) |
Guberif |
Jul 28 2016, 10:36 AM
Newbie Group: Members Posts: 33 Joined: 27-July 16 From: Washington Member No.: 20,227 Region Association: Pacific Northwest |
Hello Tim!
AWESOME Gauge Lighting! (IMG:style_emoticons/default/cheer.gif) I would love for you to do this to mine! Question, can you also correspond my aftermarket (vdo's) head temp, oil pressure, and voltage gauges to change with the main gauges, that would be too cool! Also, is there any way to make the spedo brighter? That's my main problem (tickets) never have problems knowing when to shift. just knowing when to let up off the skinny pedal on the right! Although, do have tendencies to blow up these engines, can you red adjust the head temp gauge? I've already gone thru these gauges & replaced lenses to glass and everything else I could think of. Just tell me where to send them, how much it will be and what type of payment your preference is. (IMG:style_emoticons/default/aktion035.gif) Thank's Bonnie (IMG:style_emoticons/default/piratenanner.gif) |
Lo-Fi Version | Time is now: 4th May 2024 - 05:03 AM |
