Custom Gauge Lighting, DIY kits or send them to me |
timothy_nd28 |
Aug 15 2013, 11:24 PM
Advanced Member Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest |
I'm offering a service to retrofit the backlighting on your gauge cluster.
Full service is also available for $300.00. I will do all the labor with installing these LED's, paint the needles and do other cosmetic work which also includes replacing the plastic lenses with glass (if needed). For an extra 100 dollars, I will convert your tachometer to a modern air core servo tach that will work with any 4,6 or 8 cylinder engines. Some sample backlight colors you can choose with a simple push of a button on the remote control. Below is a video showing some extra features that the controller can do. https://www.youtube.com/watch?v=Byh23MwiMLY All the gauges illuminate red when the gas gauge gets too low. There is also a tachometer sensing circuit in the controller, that will change the background color at different RPM's (you tell me what RPM's, I then calibrate the controller to your settings) |
timothy_nd28 |
Sep 19 2017, 12:57 PM
That is awesome! I appreciate the kind words
Lo-Fi Version | Time is now: 4th May 2024 - 12:13 PM |
