| dbreitkreutz |
Aug 17 2013, 12:32 PM
Newbie ![]() Group: Members Posts: 7 Joined: 20-February 11 From: Deer Park, WA. Member No.: 12,737 Region Association: Pacific Northwest |
I am trying to install a redline conversion kit #K 297. Which is the progressive two barrel weber on my 2.0 l. I cannot get the manifolds to align up properly to the cast carb base. I have tried with the swap of manifolds, but if I can get it to mate with the manifold it is way off the bubble on the level.
Has anybody used this kit that worked or not. Daniel |
| cwpeden |
Aug 17 2013, 12:39 PM
Great White North, huh? ![]() ![]() ![]() Group: Members Posts: 916 Joined: 20-August 06 From: Victoria BC Member No.: 6,693 Region Association: Canada |
Are you wearing your fireproof underwear?
No-one here will have anything good to say about this conversion. If the original FI is not an option and your looking for more power or driveability you will need to approach it differently. And so the saga begins.... Good luck and (IMG:style_emoticons/default/welcome.png) |
| zambezi |
Aug 17 2013, 12:48 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 711 Joined: 14-April 08 From: Lafayette, LA Member No.: 8,920 Region Association: South East States |
You now know one of the many reasons this kit is not recommended on our engines. Sorry can't help
| Mark Henry |
Aug 17 2013, 02:13 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
You must adjust the float on those carbs....toss it into the nearest body of water (river, pond, lake or ocean) and see if it floats.
If it floats you're good to go. |
| rick 918-S |
Aug 17 2013, 05:38 PM
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,338 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region
I'm sure you will continue to try to make it work because you have it but you will soon realize just how bad that setup is. Hopefully before you damage the engine.
| jcd914 |
Aug 17 2013, 06:42 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,098 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
Take pictures of the runners not lining up with the manifold and send the kit back to Redline and get a dual carb kit. Dual 40s are a good match for the 2.0l engine but even the dual single barrel 34s are a world better than the single weber 2bbl. Jim |
| dbreitkreutz |
Aug 18 2013, 10:45 AM
To everybody out there..
Thanks for the constructive help. Why do I get BS when I am asking a question from this forum. You cannot tell me that all of you are still running the Bosch FI.... That set-up had it's share of problems. Do not worry I will never ask a question again. |
| carr914 |
Aug 18 2013, 11:01 AM
Racer from Birth ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 134,591 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
Has anybody used this kit that worked or not. Daniel To everybody out there.. Thanks for the constructive help. Why do I get BS when I am asking a question from this forum. You cannot tell me that all of you are still running the Bosch FI.... That set-up had it's share of problems. Do not worry I will never ask a question again. Too Bad you didn't listen to the advise given. That kit is one of the Worst things ever offered for a 914. I bought a 914 with one not knowing - I soon had a New Engine. It's not that everyone is still running the FI (which is the ideal set-up for a stock motor) or Dual Webers, it's about telling you the single Holley is bad Most of the people commenting here are long-time Members who have 'been there, done that", and have seen others ask the same question. If you choose to ignore advise after your 4 Posts, then Good Luck to you and say Hi to the Dr. for us (IMG:style_emoticons/default/bye1.gif) |
| Mark Henry |
Aug 18 2013, 11:32 AM
That aboot sums it up....
I've been wrenching on VW engines for 30+ years I won't even look at one with a single progressive. Sure you can get it to run but it will never run right. Even the factory never offered a single carb on a type four engine, and seeing as it would have been cheaper you can bet they tried. Stock FI Stock dual carbs (bus) Aftermarket FI Dual Kadrons on type one Dual webers (or dells) |
| rick 918-S |
Aug 18 2013, 11:39 AM
You purchased junk headers even after seeing a "F" rating on ebay. Now you purchased a crap intake that even if carb fit it doesn't maintain proper suspension of the fuel/air and will never run correctly. You sold all your F.I. stuff in the classified cheap and were the ass holes for pointing out the errors of your ways.
We have a search function here and are more than happy to answer questions before you spend your money. I wonder what your reaction would have been if you would have asked first before buying that junk. I hope your not trying to run your big bore 2.0 with that crap. |
| Drums66 |
Aug 18 2013, 12:21 PM
914 Rudiments ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
Are you wearing your fireproof underwear? No-one here will have anything good to say about this conversion. .....Like going to hell....with gasoline draws. (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/happy11.gif) (IMG:style_emoticons/default/smoke.gif) (IMG:style_emoticons/default/bye1.gif) |
| 914itis |
Aug 18 2013, 12:51 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States |
Some people don't want to hear the truth, they want to hear what they want to hear.
Here we tell you the truth based on experience whether you like it or not. All advice given here were top notch. Good luck ! |
| bandjoey |
Aug 18 2013, 12:57 PM
bandjoey ![]() ![]() ![]() ![]() Group: Members Posts: 4,935 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Ha...We Love You Man...don't take offense. I couldn't get the old FI to work and bought 34 Dells (dual carbs) and never looked back. My stock 2.0 runs and runs, and the install fit first time. You can search single carb, progressive carb, holly carb, etc on this forum and find so many unhappy people.
Search dual carbs and see hundreds of happy people. Check the classifieds...you'll probably find a set for sale now or soon. Dellorto carbs....CB Performance web site. (IMG:style_emoticons/default/welcome.png) We're not flamming you but the product. (IMG:style_emoticons/default/ar15.gif) |
| dbreitkreutz |
Aug 19 2013, 08:34 AM
OK, I get it. I was just trying to get the "little Guy" more streetable. I have Weber's 44 IDF pair on it now. I have been trying to "tune" them now for several years and just thought this conversion might be the trick. I am wrong.
The webers need rebuilding and chocked down on the venturies and main jets. It has been loading up on fuel and killing the plugs. So I will continue to work with the 44's and return the conversion kit. I apologize for my comments and if anybody has a chart with the ratio of a main jet to the correction, if the main is sized smaller does the correction need to follow and how much. Thanks again for any help. |
| ThePaintedMan |
Aug 19 2013, 08:46 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,887 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States
OK, I get it. I was just trying to get the "little Guy" more streetable. I have Weber's 44 IDF pair on it now. I have been trying to "tune" them now for several years and just thought this conversion might be the trick. I am wrong. The webers need rebuilding and chocked down on the venturies and main jets. It has been loading up on fuel and killing the plugs. So I will continue to work with the 44's and return the conversion kit. I apologize for my comments and if anybody has a chart with the ratio of a main jet to the correction, if the main is sized smaller does the correction need to follow and how much. Thanks again for any help. It might be easier for you to give us the specs of what's installed in the 44s currently. That includes at least venturi size, main jets, idle jets, and emulsion tubes. Then we can give you a ballpark figure for you to start with and tell you where you're possibly out of spec. Keep in mind, all engines want different things, and no one can give you a perfect setup just by hearing what size engine you have. But we can give you a decent baseline, *assuming* that you have a healthy engine, and everything else is working as it should. Now would also be a good time to buy a copy of Tomlinson's Weber Tech Manual. If you own a set of Webers, it's my opinion you have to have this book. It's also my opinion that if you have carbs on your car, you must learn how they work, and how to tune them. (IMG:style_emoticons/default/welcome.png) |
Lo-Fi Version | Time is now: 11th September 2026 - 08:31 PM |
