| lsintampa |
Aug 18 2013, 10:33 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 520 Joined: 28-January 13 From: Tampa, FL Member No.: 15,441 Region Association: South East States |
75 914/4 2.0 d-jet
Boring story, but it looks like I need to get into my motor. The motor came with the car and was nice and clean. All parts that could be powder coated were, it was like new looking. It also had valves re-adjusted, leak tested (OK), and internal probes showed it to be very clean (info from PO). It sat on my garage floor for 5 months while I tended to the car's other needs. I did drop some oil into each cylinder before I put the plugs in. But the fuel feeder tubes and inlet ports were wide open for a while. But plugged with rags (noted). Anyway now that I'm finally getting around to trying to start it, the motor is all but seized up. It turns, but it is really hard to move and when it does, it sounds raspy like it's grinding something or scraping something. Hard to explain but it don't sound good. So, I'm starting all over and I'm going to drop that motor back out and get into it. It is the ONLY way that I will know for sure what I'm dealing with. Thanks for everyone that's helped along the way. I'm sure once I get into this motor, I'll be looking for help once again. (IMG:style_emoticons/default/headbang.gif) |
| Bartlett 914 |
Aug 18 2013, 10:47 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,218 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
That seems pretty extreme. How did it turn over when the rebuild was done? Maybe you should do something to put oil pressure into the system and try it.
| lsintampa |
Aug 18 2013, 11:52 AM
That seems pretty extreme. How did it turn over when the rebuild was done? Maybe you should do something to put oil pressure into the system and try it. I can only go on what I was told and what I observed since I got the car. I don't think it was rebuilt. From what I know it was cleaned, new external seals were put on and the valves adjusted. How do you get oil pressure in this motor? My first air cooled motor, I'm used to oil pumps in the sump that work off of the motor running. |
| stugray |
Aug 18 2013, 01:29 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
Did the PO possibly install a "better" oil pump during this upgrade?
Hint...Hint.... Stu |
| r_towle |
Aug 18 2013, 02:06 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
To get it primed, remove all the plugs and spin it for about 30 seconds.
That should bring oil up to the rockers which you can see if you remove one of the valve covers. Beware, it could be messy. Rich |
| lsintampa |
Aug 18 2013, 02:07 PM
| lsintampa |
Aug 18 2013, 02:09 PM
To get it primed, remove all the plugs and spin it for about 30 seconds. That should bring oil up to the rockers which you can see if you remove one of the valve covers. Beware, it could be messy. Rich If I could spin it, I wouldn't be dropping it out to tear it down. This is the major issue, it barely moves at all. |
| lsintampa |
Aug 18 2013, 02:12 PM
I can see why you all may be confused.
When I said it "turns", I meant it moves - it sure as heck doesn't turn. If I put a 30MM socket on the wheel hub and get a breaker bar, I can move it a bit, until it gets so tight that all I'm moving is the clutch on the flywheel - I think that's the rasping sound I hear. I dosed all 4 cylinders with oil for two days, but still not really freeing up. Not seeing much else to do at this point other that pull it and take a look inside. |
| Java2570 |
Aug 18 2013, 02:28 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 649 Joined: 7-May 11 From: Fishers, IN Member No.: 13,035 Region Association: Upper MidWest |
I know you've had several threads here lately about this engine....since it hasn't run for so long, do you know any history about the engine and how it was stored?
When you got it, did it actually turn better than it does now? Do you have any documentation on what was done to the motor? It would be nice if someone in your area that knows these cars could take a look at it..... |
| stugray |
Aug 18 2013, 02:50 PM
QUOTE better how? sorry I'm not getting the hint Oil pump "upgrades" to the type-I pump often result in the cam gear hitting the pump causing all kinds of "grinding" possibilities. What is the chance that the PO did a motor rebuild with a new pump, but didnt clearance it right? Stu |
| lsintampa |
Aug 18 2013, 02:55 PM
QUOTE better how? sorry I'm not getting the hint Oil pump "upgrades" to the type-I pump often result in the cam gear hitting the pump causing all kinds of "grinding" possibilities. What is the chance that the PO did a motor rebuild with a new pump, but didnt clearance it right? Stu Not sure about that. I'm sending him an email now, but I don't think the oil pump was messed with - maybe resealed, but I don't think replaced. Really don't know. Thanks! |
| Bartlett 914 |
Aug 18 2013, 03:05 PM
Sorry but I thought you rebuilt it. Remove the plugs. Does it then move? I did a install of a motor that had been sitting awhile. It was a used motor not rebuilt. Carbon had broken loose causing the motor to not turn. I did not force it. I removed the heads and cleaned them. Resealed everything and I am good. Not sure if this helps....
| r_towle |
Aug 18 2013, 05:15 PM
Sorry, throughout you fuel injector saga you kept stating that you would turn it over and no fuel was coming out of the injectors, that is why I assumed it turned over.
Just pull the motor out. It takes about a Saturday to tear it down to the crankshaft, including removal of the motor. Overall, you can rebuild one in about 30 hours, but that does not include any possible machine work. Don't be scared of the prospect, it's a fairly simple motor, and everyone here will help, kibitz, make sarcastic comments, and bust your balls three years from now when you have not finished it yet |
| lsintampa |
Aug 18 2013, 09:09 PM
Sorry, throughout you fuel injector saga you kept stating that you would turn it over and no fuel was coming out of the injectors, that is why I assumed it turned over. Just pull the motor out. It takes about a Saturday to tear it down to the crankshaft, including removal of the motor. Overall, you can rebuild one in about 30 hours, but that does not include any possible machine work. Don't be scared of the prospect, it's a fairly simple motor, and everyone here will help, kibitz, make sarcastic comments, and bust your balls three years from now when you have not finished it yet Thanks, Yeah it was turning over for a bit. Then it just seized up. There was one backfire, so timing I know was off. Got this info from the PO: "the long block was not opened up and the motor turned over by hand (plugs out) very easy, so as long as nothing got down an intake or exhaust port and ingested I would be skeptical of internal problems...that said, the flywheel was a new aftermarket unit and I did not install it, and I would investigate the front blower/fan/pulley area...the AC pulley was originally installed behind the cooling fan and the bolts that held that assembly were most likely slightly longer than the factory bolts and if the pulley was not reinstalled you could have interference with the front on the block....just my thoughts...you might want to pull the trans. to look for flywheel rubbing issues ( it looked the same but??) if not I would next look at the front end for blower fan problems that are causing rubbing and ultimately end play issues." In any event, the motor is coming out and we'll go from there. |
| stugray |
Aug 18 2013, 09:12 PM
If you reinstall the fan without the proper spacer you will have this very issue...
Stu |
| speed metal army |
Aug 18 2013, 09:55 PM
Waiting for the rain to stop... ![]() ![]() ![]() Group: Members Posts: 1,072 Joined: 4-September 10 From: PNW Member No.: 12,137 Region Association: Canada |
Not in gear is it ? Just checking....
| mepstein |
Aug 19 2013, 06:26 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,587 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
I't didn't seize from sitting in your garage for 5 months. Either it was siezed before or something is keeping it from turning. My car sat in my mom's humid garage for 22 years and the piston and cylinders looked fine and turned easily.
| lsintampa |
Aug 19 2013, 06:33 AM
If you reinstall the fan without the proper spacer you will have this very issue... Stu And if that happens, what type of damage can be expected? Curious if this turns out to be the case, what I'll be looking at. I'm assuming the motor is going to need repairs, so I'm debating now my options. Thanks Stu, Len |
| VaccaRabite |
Aug 19 2013, 06:51 AM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,845 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
Sorry, throughout you fuel injector saga you kept stating that you would turn it over and no fuel was coming out of the injectors, that is why I assumed it turned over. Just pull the motor out. It takes about a Saturday to tear it down to the crankshaft, including removal of the motor. Overall, you can rebuild one in about 30 hours, but that does not include any possible machine work. Don't be scared of the prospect, it's a fairly simple motor, and everyone here will help, kibitz, make sarcastic comments, and bust your balls three years from now when you have not finished it yet Its true. I'm proof of this. Zach |
| nathansnathan |
Aug 19 2013, 07:10 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,052 Joined: 31-May 10 From: Laguna Beach, CA Member No.: 11,782 Region Association: None |
If you reinstall the fan without the proper spacer you will have this very issue... Stu And if that happens, what type of damage can be expected? Curious if this turns out to be the case, what I'll be looking at. Without the spacer, the end of the bolts for the fan hub would tear up the crank seal. Another possibility, it could be an end play issue. If it's too much, the distributor drive gear can hang up and keep the crank from turning. Too little and it would definitely be hard to turn. It's supposed to have 3-5 thousandths play. |
Lo-Fi Version | Time is now: 2nd April 2026 - 02:17 PM |
