QUOTE(lsintampa @ Aug 18 2013, 11:09 PM)
QUOTE(r_towle @ Aug 18 2013, 07:15 PM)
Sorry, throughout you fuel injector saga you kept stating that you would turn it over and no fuel was coming out of the injectors, that is why I assumed it turned over.
Just pull the motor out.
It takes about a Saturday to tear it down to the crankshaft, including removal of the motor.
Overall, you can rebuild one in about 30 hours, but that does not include any possible machine work.
Don't be scared of the prospect, it's a fairly simple motor, and everyone here will help, kibitz, make sarcastic comments, and bust your balls three years from now when you have not finished it yet
Thanks,
Yeah it was turning over for a bit. Then it just seized up. There was one backfire, so timing I know was off.
Got this info from the PO:
"the long block was not opened up and the motor turned over by hand
(plugs out) very easy, so as long as nothing got down an intake or exhaust
port and ingested I would be skeptical of internal problems...that said, the
flywheel was a new aftermarket unit and I did not install it, and I would
investigate the front blower/fan/pulley area...the AC pulley was originally
installed behind the cooling fan and the bolts that held that assembly were
most likely slightly longer than the factory bolts and if the pulley was not
reinstalled you could have interference with the front on the block....just
my thoughts...you might want to pull the trans. to look for flywheel rubbing
issues ( it looked the same but??) if not I would next look at the front end
for blower fan problems that are causing rubbing and ultimately end play
issues."
In any event, the motor is coming out and we'll go from there.
The statement about the fan, and the flywheel would inspire me to remove the motor, and remove the transmission,
First I would check out the fan to make sure that was not biding in anyway.
Lots of pictures posted will help diagnose that here.
Then I would check the flywheel end play.
The flywheel, if ground or refaced, would then require (possibly) grinding down of the bolt heads that hold the flywheel to the crankshaft.
Otherwise , the clutch disk hits them, causing binding with the transmission, in or out of gear...
Pull it, pull the tranny and pressure plate, look for marks on the bolt heads and the clutch disk.
Then, see if you can turn it by hand using one of the flywheel bolts, not the front fan bolt because that front bolt WILL break.
rich
