#770 (912E) Project thread *Tangerine Cooling System installed!) |
Bulldog9 |
Aug 21 2013, 08:44 PM
Senior Member Group: Members Posts: 705 Joined: 21-August 13 From: United States Member No.: 16,283 Region Association: MidAtlantic Region |
I'm restoring a 912E, total gut & rebuild. New to this forum, been on the 912 board and several others for a while. I've never worked on an air cooled car engine before, or VW/Porsche of any type, so this has been a real learning process. Been lurking here for a while, figured it was time to post. I've been on 912BBS since 2011, for those interested, this link goes back to day 1. http://www.912bbs.org/vb/showthread.php?43391-770-Update
Bulldog9 |
Nov 11 2013, 07:05 PM
Am looking at a couple fuel pumps for my build.
Is a 2056 with Weber 40's. Looking at these two pumps as a start, any experience with these? Obviously looking for reliability. Also, do I need to run a regulator and fuel return back to the tank with this low a pressure? I've come across this http://www.amazon.com/FRAM-G3583-In-Line-F...r/dp/B000AMW0F6 as a possible alternative to a pressure regulator, would be an easy fit, plan to keep stock filter and plumbing and put this in beween the stock filter and carbs, then plumb in the return. But is it needed? Good insrurance? Here are the pumps. a CB, Mer Gasket and Carter. http://www.cbperformance.com/ProductDetail...roductCode=3193 http://www.summitracing.com/parts/mrg-42s/overview/ http://www.jegs.com/i/Carter/180/P4070/10002/-1 Thanks! |
SirAndy |
Nov 11 2013, 08:08 PM
Resident German Group: Admin Posts: 41,641 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I used the CB rotary pump on my 2056 and it worked great and was quiet ... (IMG:style_emoticons/default/shades.gif) |
Lo-Fi Version | Time is now: 18th May 2024 - 12:39 AM |
