#770 (912E) Project thread *Tangerine Cooling System installed!) |
Bulldog9 |
Aug 21 2013, 08:44 PM
Senior Member Group: Members Posts: 705 Joined: 21-August 13 From: United States Member No.: 16,283 Region Association: MidAtlantic Region |
I'm restoring a 912E, total gut & rebuild. New to this forum, been on the 912 board and several others for a while. I've never worked on an air cooled car engine before, or VW/Porsche of any type, so this has been a real learning process. Been lurking here for a while, figured it was time to post. I've been on 912BBS since 2011, for those interested, this link goes back to day 1. http://www.912bbs.org/vb/showthread.php?43391-770-Update
Bulldog9 |
Aug 29 2013, 04:55 PM
Thanks for the welcome guys, I will definitely be checking in here for some help as I build the motor. I took the flywheel to a second shop they said the flywheel was fine, so they are going to clean and do a light resurface.
Here is a question, my cooling fan is pitted and dirty, what is the best way to restore? I'd like to powder coat, but am a bit concerned about the cleaning and effecting the balance of the fan. SHOULD start the assembly of the long block after laborday weekend. |
euro911 |
Aug 29 2013, 07:13 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,848 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Thanks for the welcome guys, I will definitely be checking in here for some help as I build the motor. I took the flywheel to a second shop they said the flywheel was fine, so they are going to clean and do a light resurface. The fan and pulley were balanced at the factory, so be mindful when you take it apart - make a mark on the fan that lines up with the small weight embedded in the fold on the pulley. Here is a question, my cooling fan is pitted and dirty, what is the best way to restore? I'd like to powder coat, but am a bit concerned about the cleaning and effecting the balance of the fan. SHOULD start the assembly of the long block after labor day weekend. Blast away and paint or powder-coat the pulley as desired. Some folks paint the fan too. Repaint your timing marks (red or white) and carry the timing marks all the way to the other side of the fan so it's easier to see from any angle. |
Lo-Fi Version | Time is now: 3rd May 2024 - 02:09 PM |
