#770 (912E) Project thread *Tangerine Cooling System installed!) |
Bulldog9 |
Aug 21 2013, 08:44 PM
Senior Member Group: Members Posts: 705 Joined: 21-August 13 From: United States Member No.: 16,283 Region Association: MidAtlantic Region |
I'm restoring a 912E, total gut & rebuild. New to this forum, been on the 912 board and several others for a while. I've never worked on an air cooled car engine before, or VW/Porsche of any type, so this has been a real learning process. Been lurking here for a while, figured it was time to post. I've been on 912BBS since 2011, for those interested, this link goes back to day 1. http://www.912bbs.org/vb/showthread.php?43391-770-Update
Bulldog9 |
Nov 14 2013, 07:17 AM
Thanks all, I decided on the CB rotary pump.
I just finished media blasting the fan, will be painting then sending crank, fan flywheel, and PP to be balanced. I weighed my piston/ring/rod assemblies and tehy are almost spot on, but will match opposing sides as close as possible. Quick question, I have been planning on using permatez aviation sealant for my case/assembly sealent, is this still the conventional wisdom? \ |
Jeffs9146 |
Nov 14 2013, 11:12 AM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
Thanks all, I decided on the CB rotary pump, and will likely use the Fram filter with the built in bypass as a second filter. The Jeep guys use this when running Weber IDF's with great results. I just finished media blasting the fan, will be painting then sending crank, fan flywheel, and PP to be balanced. I weighed my piston/ring/rod assemblies and tehy are almost spot on, but will match opposing sides as close as possible. Quick question, I have been planning on using permatez aviation sealant for my case/assembly sealent, is this still the conventional wisdom? I'm going to try to keep all my questions and posts on the car in this thread, would like to rename it if possible, to #770 Build Project (my 912E is #770 of about 2000). Moderators??? You can change the title yourself by going to your first post while loged in and click on edit, then full edit and go to the top of the new screen and change your title! |
Lo-Fi Version | Time is now: 3rd May 2024 - 03:12 PM |
