#770 (912E) Project thread *Tangerine Cooling System installed!) |
Bulldog9 |
Aug 21 2013, 08:44 PM
Senior Member Group: Members Posts: 705 Joined: 21-August 13 From: United States Member No.: 16,283 Region Association: MidAtlantic Region |
I'm restoring a 912E, total gut & rebuild. New to this forum, been on the 912 board and several others for a while. I've never worked on an air cooled car engine before, or VW/Porsche of any type, so this has been a real learning process. Been lurking here for a while, figured it was time to post. I've been on 912BBS since 2011, for those interested, this link goes back to day 1. http://www.912bbs.org/vb/showthread.php?43391-770-Update
euro911 |
Sep 5 2013, 04:41 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,848 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Another neat trick is to drill a 1/2" hole in the rear engine tin at the flywheel. Paint the factory TDC gouge with a nice bright color and paint another (wider one) 180 degrees out for BDC.
This comes in handy for ignition timing when topside and the marks on the flywheel also help when down below, adjusting the valves (IMG:style_emoticons/default/idea.gif) |
Cap'n Krusty |
Nov 30 2013, 08:32 PM
Another neat trick is to drill a 1/2" hole in the rear engine tin at the flywheel. Paint the factory TDC gouge with a nice bright color and paint another (wider one) 180 degrees out for BDC. This comes in handy for ignition timing when topside and the marks on the flywheel also help when down below, adjusting the valves (IMG:style_emoticons/default/idea.gif) Why would you want to look at marks on the flywheel when adjusting the valves? The Cap'n |
Lo-Fi Version | Time is now: 3rd May 2024 - 02:34 PM |
