#770 (912E) Project thread *Tangerine Cooling System installed!) |
Bulldog9 |
Aug 21 2013, 08:44 PM
Senior Member Group: Members Posts: 705 Joined: 21-August 13 From: United States Member No.: 16,283 Region Association: MidAtlantic Region |
I'm restoring a 912E, total gut & rebuild. New to this forum, been on the 912 board and several others for a while. I've never worked on an air cooled car engine before, or VW/Porsche of any type, so this has been a real learning process. Been lurking here for a while, figured it was time to post. I've been on 912BBS since 2011, for those interested, this link goes back to day 1. http://www.912bbs.org/vb/showthread.php?43391-770-Update
Bulldog9 |
Feb 1 2014, 05:41 PM
R&R'd the steering rack and front cross member today, things are coming along! Here is a before & after. Details are on the main build thread. Also test fit the sachs/Boge strut inserts, fit perfectly. Will be cleaning them up over the next few days.
http://www.912bbs.org/vb/showthread.php?43...70-Update/page4 Attached thumbnail(s) |
barefoot |
Feb 10 2014, 07:53 AM
Senior Member Group: Members Posts: 1,270 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
R&R'd the steering rack and front cross member today, things are coming along! Here is a before & after. Details are on the main build thread. Also test fit the sachs/Boge strut inserts, fit perfectly. Will be cleaning them up over the next few days. http://www.912bbs.org/vb/showthread.php?43...70-Update/page4 You don't show torsion bars or rear bushings in front A-arms, beware that worn OEM bushings sag and cause bars to rub the ID of the A-arm and create grooves and corrosion pits that may result in fracture of the bars. Replacement of the bushings is easy and should be done if you haven'r already been there. If the torsion bars have the coating warn away be sure to polish the bars to remove any grooves or corrosion and re-coat. |
Lo-Fi Version | Time is now: 3rd May 2024 - 05:31 PM |
