FS Alloy lug nut set - replated - extras |
bdstone914 |
Aug 21 2013, 09:45 PM
bdstone914 Group: Members Posts: 4,520 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
SOLD The full set.
There are seven more that the PO ground of the radiused head so they would clear on the adapters that were used. Good for spares. $5 each Shipping $6 USPS flat rate box. Attached thumbnail(s) |
jesiv |
Aug 22 2013, 07:18 PM
Senior Member Group: Members Posts: 552 Joined: 5-August 07 From: Pensacola/Milton, Florida Member No.: 7,975 Region Association: Northern California |
I am interested. If these are stock for 4 lug Fuchs and the plating won't peel off when tightened with a lug wrench. Can you provide the overall length. Not trying to rain on your parade but have been burnt before
Regards James |
bdstone914 |
Aug 22 2013, 07:32 PM
I am interested. If these are stock for 4 lug Fuchs and the plating won't peel off when tightened with a lug wrench. Can you provide the overall length. Not trying to rain on your parade but have been burnt before Regards James They are factory 38mm lug bolts. The length is measured excluding the head. It is a good plating job that will not peal. The zinc will scratch when used with a steel lug wrench. This is the same as the factory finish. Bruce |
jesiv |
Aug 22 2013, 07:44 PM
That being the case. I will take them. PM me your Paypal info
Regards James |
Lo-Fi Version | Time is now: 15th May 2024 - 03:33 AM |
