QUOTE(jesiv @ Aug 22 2013, 06:18 PM)
I am interested. If these are stock for 4 lug Fuchs and the plating won't peel off when tightened with a lug wrench. Can you provide the overall length. Not trying to rain on your parade but have been burnt before
Regards
James
They are factory 38mm lug bolts. The length is measured excluding the head.
It is a good plating job that will not peal. The zinc will scratch when used with a steel lug wrench. This is the same as the factory finish.
Bruce
