How do you adjust your windows?, Mine let a "little" water in... |
ChrisReale |
Dec 10 2004, 01:00 AM
Ok, so a lot of water gets in when it rains. Prolly because there is a gap between the window and the rubber seal. How do you adjust your side windows so that there is no gap?
Aaron Cox |
Dec 10 2004, 01:02 AM
ive read the description in the haynes manual before....
early cars are different then late models. (IMG:style_emoticons/default/wink.gif) |
ChrisReale |
Dec 10 2004, 01:05 AM
QUOTE(Aaron Cox @ Dec 9 2004, 11:02 PM) haynes manual I gots one of them..thanks. Is the description the reverse order of how it is takem apart? (IMG:style_emoticons/default/laugh.gif) |
sj914 |
Dec 10 2004, 01:07 AM
Which rubber seal? The Vertical on the rollbar or the horizontal one thats on the top?
If you have the later style window mechanism, you can adjust it to roll up more. If the window isn't making enough contact with the rubber, because it looks like it's pryed out a bit. You can adjust the window guide at the bottom of the door. |
ChrisReale |
Dec 10 2004, 01:17 AM
along the side, between the vertical rubber and the window, there is a gap.
Aaron Cox |
Dec 10 2004, 01:19 AM
there is a few types of adjustments: tilt (in towards car/out) height, and angle fromt to back (mine is lower in the back (IMG:style_emoticons/default/wacko.gif) )
sj914 |
Dec 10 2004, 01:21 AM
Just adjust the window guide. There's an adjuster at the bottom of the door.
markb |
Dec 10 2004, 01:25 AM
It all comes down to trial & error (more error on my part). (IMG:style_emoticons/default/biggrin.gif)
McMark |
Dec 10 2004, 01:44 AM
If it's not connecting in the back, you might need to adjust your striker plate for the door latch. Undo the big ass phillips screws and push it towards the center of the car. your doors should be snug* to open and close.
*snug being a firm push required to close the door, and pulling the handle should take more than one finger. |
wheelo |
Dec 10 2004, 01:55 AM
Dude Group: Members Posts: 265 Joined: 19-March 04 From: San Rafael, Ca Member No.: 1,818 |
I also get some H20, coming from the area where the targa-top, meets the top corner of the wing-window.
Funny though..... Faster I drive... the less it leaks ...... (IMG:style_emoticons/default/wink.gif) |
mightyohm |
Dec 10 2004, 02:11 AM
QUOTE(wheelo @ Dec 9 2004, 11:55 PM) I also get some H20, coming from the area where the targa-top, meets the top corner of the wing-window. Funny though..... Faster I drive... the less it leaks ...... (IMG:style_emoticons/default/wink.gif) I think leaks in that area are pretty normal. I have that too. It's the worst when the car is parked. |
ChrisReale |
Dec 10 2004, 02:24 AM
I know it isn't going to be water tight. But I want to avoid having 4" of water on the floor after a heavy rain (IMG:style_emoticons/default/barf.gif)
wheelo |
Dec 10 2004, 02:29 AM
Yeah, I had the same exact leak in my '70 teener, was able to create a small seal with some black RTV (silicone) inbetween the targa-top and seal. Works for a while, untill you remove & replace top, several times. Then just need to re-apply .... I should do on current car.... this was the first real rain we have had, and now I know, same .....
(IMG:style_emoticons/default/icon_bump.gif) |
ruddyboys |
Dec 10 2004, 07:06 AM
Hummel eigentümer Group: Members Posts: 594 Joined: 3-March 04 From: Monroe, NY Member No.: 1,749 Region Association: North East States |
not to steal this thread, but my wing window is loose, how do you tighten that.
East coaster |
Dec 10 2004, 07:26 AM
Senior Member Group: Members Posts: 1,660 Joined: 28-March 03 From: Brigantine, NJ Member No.: 487 Region Association: None |
It's a shame our cars have to leak so bad. It would be awesome to have modern day seals designed for our cars. There's really no reason they have to leak like they do if modern seal technology could be applied. I've owned about 10 914s and all of them leaked like a sieve whether they had new seals or not.
Of course it may seem too strange to drive a 914 in the rain without a constant drip on my left knee! What next, a fog free windshield?? (IMG:style_emoticons/default/blink.gif) |
aircooledboy |
Dec 10 2004, 08:57 AM
Sweet Pea's 1st ride in daddy's "vroom -vroom" Group: Members Posts: 1,672 Joined: 4-February 04 From: Rockford, IL Member No.: 1,629 Region Association: Upper MidWest |
The problem is not the seals, unfortunately. New or good seals will reduce the problem, but eliminating the leaks is almost impossible due to a 30 year old design. (IMG:style_emoticons/default/headbang.gif)
In our cars, the only things guiding the window as it closes are the channel at the front and the regulator where it attaches to the bottom of the glass. As "frameless" door windows have evolved over the years, manufacturers have learned that they needed to add plastic "guides" to the bottom of the glass that engage with alighment pieces as the window reaches the closed position, firming up the fit into just the right spot. These designs have really only been perfected in the last 10 years or so, and there is no way to retro-fit them to our cars. (IMG:style_emoticons/default/confused24.gif) |
Joe Ricard |
Dec 10 2004, 09:09 AM
Just waiting for someone here to say thier car don't leak. (IMG:style_emoticons/default/bs.gif)
I bought the car without carpeting. I will certainly leave it this way as I can wipe up the water once I return home. The PO applied an epoxy paint that has stood up fairly well considering the abuse it gets. Not having carpet also bumped me in AX class but who cares atleast I have rust free floor boards (IMG:style_emoticons/default/mueba.gif) |
scotty914 |
Dec 10 2004, 09:30 AM
suby torque rules Group: Members Posts: 1,525 Joined: 20-July 03 From: maryland, the land of 25 year Member No.: 924 |
my car has not leaked in a year and a half
but then again its inside |
SGB |
Dec 10 2004, 09:52 AM
Replacing the fuzzy strips inside is easy and helps tighten up the window. There are several adjustment locations; a screw on the winder part of the regulator limits upward traval. There is a screw through the bottom of the door, near the rear, to adjust rake in and out. Make sure the screw at the top of the track near the door handle is tight, too.
STL914 |
Dec 10 2004, 11:53 AM
Senior Member Group: Members Posts: 1,180 Joined: 22-October 03 From: O'Fallon, MO Member No.: 1,271 Region Association: Upper MidWest |
Some what related to this thread, the first experience I had discovering my first 914 leaked was going through a car wash.
What an eye opener. I dropped my wife off to get us some sodas for the days PCA drive. I decided to get the car washed to give a good first impressiom to the other club members. I got completely drenched. (IMG:style_emoticons/default/headbang.gif) My wife laughed her ass off, until she put that same ass into her water filled passenger seat. (IMG:style_emoticons/default/chairfall.gif) |
Lo-Fi Version | Time is now: 3rd May 2024 - 05:03 AM |
