AN oil lines for a six |
914itis |
Aug 22 2013, 10:25 PM
Who makes an AN oil line from the motor to the tank to replace the one in the picture?
Attached thumbnail(s) |
stugray |
Aug 22 2013, 10:28 PM
This one?
http://www.patrickmotorsports.com/part/pmp...onversion-part/ If not, they will have what you need. Stu |
914itis |
Aug 22 2013, 10:35 PM
This one? http://www.patrickmotorsports.com/part/pmp...onversion-part/ If not, they will have what you need. Stu Stu, that looks kind of short. I think this is just the end flex piece. |
gms |
Aug 22 2013, 11:04 PM
Advanced Member Group: Members Posts: 2,695 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest |
here is a chart
Aug 22 2013, 11:22 PM
Don't the stock hoses have metric ends? AN has inch sizes, in sixteenths of an inch; AN-8 is 1/2" ID hose.
If the stock hose is metric, then the answer to your question is "Nobody does." You'd need some adapters and a hose of the correct length. --DD |
914itis |
Aug 23 2013, 12:01 AM
Dave ,
You are correct, my question was, does anyone Makes the adapter and hose ? |
Larry.Hubby |
Aug 23 2013, 01:02 AM
Member who doesn't post much, but has a long time in 914s Group: Members Posts: 186 Joined: 24-November 04 From: Palo Alto, CA Member No.: 3,172 Region Association: Northern California |
As Dave said, the key things are the metric end fittings. If you have those, you can use common AN hose that lots of people sell. Here's a link to one source of both AN hose and metric end fittings:
http://97.74.32.155/files/metric.pdf |
GeorgeRud |
Aug 23 2013, 06:11 AM
The line Patrick sells will bring the oil line up past the heat exchangers, the you simply have a hose made up with 3/4" hose and AN-12 fittings to attach to the oil tank.
There are metric to AN adapters made that attach to the engine block directly, but I'm not sure that the hose leading all the way to that fitting fits as nicely as the Patrick item. |
914itis |
Aug 23 2013, 07:00 AM
As Dave said, the key things are the metric end fittings. If you have those, you can use common AN hose that lots of people sell. Here's a link to one source of both AN hose and metric end fittings: http://97.74.32.155/files/metric.pdf Great info Lary. Now the question is what size adapter do I need for the engine end ? |
6freak |
Aug 23 2013, 07:20 AM
Don't the stock hoses have metric ends? AN has inch sizes, in sixteenths of an inch; AN-8 is 1/2" ID hose. If the stock hose is metric, then the answer to your question is "Nobody does." You'd need some adapters and a hose of the correct length. --DD correct IFAIK I wanted new ones NLA (IMG:style_emoticons/default/smile.gif) |
stugray |
Aug 23 2013, 07:21 AM
Call Patrick motorsports.
Aug 23 2013, 10:51 AM
The line Patrick sells will bring the oil line up past the heat exchangers, the you simply have a hose made up with 3/4" hose and AN-12 fittings to attach to the oil tank. There are metric to AN adapters made that attach to the engine block directly, but I'm not sure that the hose leading all the way to that fitting fits as nicely as the Patrick item. (IMG:style_emoticons/default/agree.gif) That's what i have. The reason the PMS line is shorter is so you can run an external oil cooler. In the pics below, you can see the hose going to the thermostat to the right instead of going left to the tank as you would on a stock engine. (IMG:http://www.914world.com/bbs2/uploads/post-179-1182813901.jpg) (IMG:http://www.914world.com/bbs2/uploads/post-179-1182813901.jpg) |
jt914-6 |
Aug 23 2013, 12:56 PM
Driving & working on teeners 41 years Group: Members Posts: 1,786 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States |
Here are some adaptors. I used the female on my oil tank/oil cooler on my conversion six. Used 12an lines..... https://www.pegasusautoracing.com/group.asp...ID=PLUMADAP30MM
914itis |
Aug 23 2013, 02:12 PM
Thanks all,
I spoke to Brian at Patrick motorsports, he has all the hoses that I will need, at a reasonable price. |
PRS914-6 |
Aug 23 2013, 02:15 PM
Lo-Fi Version | Time is now: 17th May 2024 - 12:31 AM |
