QUOTE(GeorgeRud @ Aug 23 2013, 05:11 AM)
The line Patrick sells will bring the oil line up past the heat exchangers, the you simply have a hose made up with 3/4" hose and AN-12 fittings to attach to the oil tank.
There are metric to AN adapters made that attach to the engine block directly, but I'm not sure that the hose leading all the way to that fitting fits as nicely as the Patrick item.
That's what i have. The reason the PMS line is shorter is so you can run an external oil cooler.
In the pics below, you can see the hose going to the thermostat to the right instead of going left to the tank as you would on a stock engine.
