2 Pages V < 1 2
> Aftermarket fuel pump, What are my best options?
r_towle
post Aug 26 2013, 08:03 PM
Post #21
Custom Member
OEM pump was 65 psi but I cannot recall the GPh.
I went into the local store with those specs and found a delco pump, same size and shape, two port.
No issues at all for the p1800 ES, been quite a few years now...at least five or more.
I got the specs from the Volvo manual, but the djet is all the same in a Volvo except the mps, and the temp sensors.
At the time I went looking the Bosch pump was well over 200 bucks and we wanted to see if there was another option.
I documented it here in a thread...maybe I even put a part number.
I was less than 75 bucks.
Rich
saigon71
post Aug 29 2013, 06:02 AM
Post #22
Thanks for the instructions on the plumbing! (IMG:style_emoticons/default/beerchug.gif)
Installed the new Bosch two port fuel pump from GPR yesterday. Made a trip to the local ACE for the hardware I needed. I ended up going with a 59 cent pipe mount to secure the pump to the firewall. I didn't want to drill new holes, so I modified it slightly to line up with the mounting holes of the original 3 port clamp. Cut pieces of rubber hose as vibration dampeners where the mount meets the firewall. The pump itself pulled up tight against the firewall as well, so I ran a piece of thick mastic electrical tape along the back of the pump. A couple lengths of hose on the supply side, some brass hose menders and it was done:
JawjaPorsche
post Aug 29 2013, 06:10 AM
Post #23
QUOTE(saigon71 @ Aug 29 2013, 08:02 AM) *
Wow! That looks good! Neat as a pin! You do good work! (IMG:style_emoticons/default/beerchug.gif)
2 Pages V < 1 2
- Lo-Fi Version Time is now: 1st August 2025 - 06:24 PM
