1973 loose wires behind the dash |
HalfMoon |
Aug 27 2013, 03:52 PM
Senior Member Group: Members Posts: 828 Joined: 13-November 12 From: Shenandoah Junction, WV Member No.: 15,144 Region Association: MidAtlantic Region |
Imagine my dismay when today I decided to open the dash (I was trouble shooting a fuel gauge not working-easy fix, PO had cut the wires at the tank for some reason), discovering a huge amount of loose wires. The PO had installed a completly different tach so I'm hoping alot of these wires (11) had a purpose for being disconnected. Vain hope most likely...
I did notice the brake warning light stays on all the time...and of course nothing else works (except the fuel gauge that I just hooked back up). The car is a v-8 converted teener so alot of stuff may be disconnected for that reason as well. The real problem is that I'm VERY color blind. I can read a schematic reasonably well if I know what color wires I'm looking at on the car, which brings us to the reason for this post! Could someone help me identify the loose wires I've numbered in the enclosed photograph? What color corresponds to the numbered wires? With that data I should be able to figure out what was supposed to go where and assimilate if it was disconnected for purpose. Wiring and color blindness can be a serious challenge, so any help is appreciated :-) David Oh and btw, if you click on the image and then click again you'll get a very close view |
HalfMoon |
Aug 28 2013, 05:45 PM
Sigh. Well I goofed around with the pod wires some more today and we were right the wires 9, 10, 11 (from the previous photo's) were indeed illumination. So now I have a fuel gauge and the pods illuminated.
Sadly I simply wasn't able to identify the turn signal wires (using a test light-I did find some that corresponded to the turn signal switch, but once tested, they would continue to flash on the dash even when off). I have at least achieved a working fuel gauge and pod illumination, so now I can drive it at night...if I'm brave. Most of the other things I didn't need nor would it be possible to connect them (e-brake for instance). The Gen, oil have dedicated gauges elsewhere and I know when my brights are on and when my brakes are having a pressure problem. Pity about the turn signals but the flasher makes a clicking noise when they're in use.... I've enclosed another picture of what is leftover that I have no idea about. Commentary welcome but please remember, this is a 1973 and is quite different than cars built after 1973. Anywho...thanks alot for all the imput but it's time to move on to some other pressing problems with this car. D |
HalfMoon |
Aug 29 2013, 01:16 PM
Sigh. Well I goofed around with the pod wires some more today and we were right the wires 9, 10, 11 (from the previous photo's) were indeed illumination. So now I have a fuel gauge and the pods illuminated. Sadly I simply wasn't able to identify the turn signal wires (using a test light-I did find some that corresponded to the turn signal switch, but once tested, they would continue to flash on the dash even when off). I have at least achieved a working fuel gauge and pod illumination, so now I can drive it at night...if I'm brave. Most of the other things I didn't need nor would it be possible to connect them (e-brake for instance). The Gen, oil have dedicated gauges elsewhere and I know when my brights are on and when my brakes are having a pressure problem. Pity about the turn signals but the flasher makes a clicking noise when they're in use.... I've enclosed another picture of what is leftover that I have no idea about. Commentary welcome but please remember, this is a 1973 and is quite different than cars built after 1973. Anywho...thanks alot for all the imput but it's time to move on to some other pressing problems with this car. D Still quite baffled. I'd really like to identify what should be the illumination wires for the turn signal indicaters in the combo gauge. I thought I had it when I used a test light and operated the switch but when I placed the lever in the neutral position the flashers turned off but the indicater lights in the gauge kept flashing. I can't tell the color wires so they're numbered. Can anyone read the schematic (several post up) and tell me the number (very color blind) wires that "should" trigger the turn signal gauge lights? |
Lo-Fi Version | Time is now: 19th May 2024 - 08:14 AM |
