New Engine going in the car today, Finally ready to install |
DNHunt |
Dec 11 2004, 07:59 AM
Last thing I did was check the fluids and it's ready to go.
Eric_Shea |
Dec 13 2004, 05:19 PM
We're getting tired of waiting. Hurry up and fire that damn thing up!
We want a driving report (IMG:style_emoticons/default/w00t.gif) (IMG:style_emoticons/default/driving.gif) |
DNHunt |
Dec 13 2004, 05:41 PM
It's gonna be a while till I drive it. There won't be much time to spend on it until after Christmas. I just hope to get the problems solved so I know it will go so I'm not so obcessed by it
Dave |
dinomium |
Dec 13 2004, 06:18 PM
Git on a chair son, all the good stuff is goin over yer head! Group: Benefactors Posts: 2,777 Joined: 2-January 03 From: Bremerton, WA Member No.: 74 Region Association: Pacific Northwest |
Oh Dave... admitting the obsession is the first step to have a second 914!
HA!~ I will have some time off in btween Christmas and New Years if you need some extra "help"... Does your multi meter have a temp setting? Mine does! |
DNHunt |
Dec 15 2004, 07:29 AM
I solved the fuel pump issue. It turns out that it was a software thing. The logic in the lfuel pump circuit is the same as D-jet. If the ECU doesn't see the engine crank it shuts off the fuel pump and that was what was happenning. MS lets you set a cranking speed and mine was set too high so the ECU shut the pump down thinking that the engine was not cranking. As soon as I entered an appropriate RPM everthing worked.
The good news is that this proves that the ECU is seeing a tach signal from the Ford ignition module so the crank sensor is working and the module is alive. It may run yet. This afternoon I'll adjust the fuel pressure and work on spark. Dave |
Rocky |
Dec 15 2004, 09:02 AM
From the cockpit Group: Members Posts: 341 Joined: 24-March 04 From: Gig Harbor,WA Member No.: 1,845 |
Nice job Dave. Looks great. Let me know when your ready to drive or drive it by my place for a warm up. (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/clap56.gif)
Tim |
rhodyguy |
Dec 15 2004, 10:23 AM
i thought you would'nt have any time until after christmas. (IMG:style_emoticons/default/biggrin.gif)
kevin |
DNHunt |
Dec 15 2004, 11:56 AM
Had to get up and pee at 3:15 this morning, went back to bed and started mentally beating myself up. "Get up and get something done you lazy SOB". I got a damn drill sargent in my head. I must be getting close to Multiple Personnality Disorder brought on by obcessing about 914s.
I must be sick. I'm sure tired now. Betsy said I can work on it this afternoon after work. Dave |
Bleyseng |
Dec 15 2004, 04:52 PM
Well, is it running yet?? Waiting for you to get all the bugs worked out so I can then switch over to MS without all these headaches.
Geoff (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 08:08 PM |
