Fs Alignment Shims 2mm, 3mm, 4mm and cover plates |
bdstone914 |
Aug 29 2013, 02:32 PM
bdstone914 Group: Members Posts: 4,520 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Yes, another shim add.
Quantities are updated to reflect parts sold I have about 20 2mm shims 8 4mm shims 3 sets of cover plates All shims and cover plates are zinc plated. Also have 6 pairs of cover plates with new Schnoor washers. These washers should be replaces as they are intended for one time use. Be aware that you may need longer bolts if you increase the shim pack too much. Standard bolt length is 50mm and longer bolts are 70mm. I have seen both 8.8 and 10.8 grade bolts used on 914's. Shims are $12 per pair Cover plates $15 per pair Schnoor washers $2.50 for six. Shipping $6 USPS flat rate box Attached thumbnail(s) |
sbsix |
Aug 29 2013, 06:49 PM
only the lead dog enjoys a change in scenery... Group: Members Posts: 450 Joined: 10-January 12 From: Santa Barbara, CA Member No.: 13,990 Region Association: Southern California |
Bruce, I'll take #4 2mm shims, #2 3mm shims, a pair of cover plates and a set of washers.
Gary |
somd914 |
Aug 29 2013, 07:59 PM
Member Group: Members Posts: 1,171 Joined: 21-February 11 From: Southern Maryland Member No.: 12,741 Region Association: MidAtlantic Region |
I'll take two of each if you still have them along with a set of covers. Will also follow up with a PM. Thanks
bdstone914 |
Aug 29 2013, 08:17 PM
Kansas 914 |
Sep 2 2013, 06:40 AM
Hi Bruce,
I'll take 2 of the 2mm shims and 2of the 3mm shims, a pair of cover plates and a set of washers. Let me know the total shipped to 81301, unless you are coming to RRC this week.... |
bdstone914 |
Sep 2 2013, 08:47 AM
Hi Bruce, I'll take 2 of the 2mm shims and 2of the 3mm shims, a pair of cover plates and a set of washers. Let me know the total shipped to 81301, unless you are coming to RRC this week.... Hi Mike. total $46 $12 + 12 + 15 + 6 shipping. Good to hear from you. Bruce |
Lo-Fi Version | Time is now: 15th May 2024 - 08:37 AM |
