bdstone914
Aug 29 2013, 02:32 PM
Yes, another shim add.
Quantities are updated to reflect parts sold
I have about 20 2mm shims
8 4mm shims
3 sets of cover plates
All shims and cover plates are zinc plated.
Also have 6 pairs of cover plates with new Schnoor washers. These washers should be replaces as they are intended for one time use.
Be aware that you may need longer bolts if you increase the shim pack too much.
Standard bolt length is 50mm and longer bolts are 70mm. I have seen both 8.8 and 10.8 grade bolts used on 914's.
Shims are $12 per pair
Cover plates $15 per pair
Schnoor washers $2.50 for six.
Shipping $6 USPS flat rate box
sbsix
Aug 29 2013, 06:49 PM
Bruce, I'll take #4 2mm shims, #2 3mm shims, a pair of cover plates and a set of washers.
Gary
somd914
Aug 29 2013, 07:59 PM
I'll take two of each if you still have them along with a set of covers. Will also follow up with a PM. Thanks
bdstone914
Aug 29 2013, 08:17 PM
QUOTE(somd914 @ Aug 29 2013, 06:59 PM)
Still have them. PM replied to
Bruce
Kansas 914
Sep 2 2013, 06:40 AM
Hi Bruce,
I'll take 2 of the 2mm shims and 2of the 3mm shims, a pair of cover plates and a set of washers.
Let me know the total shipped to 81301, unless you are coming to RRC this week....
bdstone914
Sep 2 2013, 08:47 AM
QUOTE(Kansas 914 @ Sep 2 2013, 05:40 AM)
Hi Bruce,
Hi Mike.
total $46
$12 + 12 + 15 + 6 shipping.
Good to hear from you.
Bruce
